It sounds like you do not actually have the ANI Sidetone enabled. Have them go to, Channel Profiles > Analog > PTT Signaling TAB > In the Settings Box, Check the Audible Sidetone.Also if you want it so ID each and every time set the ANI suppression time to " 0 " (Zero). This is the amount time the radio will wait after it last send out the ANI before sending it out. This is a cool option. Also the MDC1200 Side tone is the actual MDC1200 Burst.
