Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Industry Discussion
Industry Discussion General discussion forum for commercial and professional radio technologies. This includes manufacturers not listed below.
Old 03-09-2012, 3:30 PM
Kingmobileaudio's Avatar
Send a message via AIM to Kingmobileaudio Send a message via MSN to Kingmobileaudio Send a message via Yahoo to Kingmobileaudio Send a message via Skype™ to Kingmobileaudio
Default Two tone decoder receiver.
I have no idea if they even make this. A radio receiver that decodes two tones that you can hook up to a PC and have it send emails out with audio clips.
I have tried software with a scanner but the false trip rate is to high.
Sent from my HTC EVO 3D using Tapatalk
(402) 937-8578
Old 03-09-2012, 8:58 PM
ramal121's Avatar
Cool
Never heard of a radio that will do that. There are plent of radios that will decode two-tone and will give you a logic signal to boot. Beyond that you'll have to hunt for software that could utilize the signal and do the appropriate processing.
The fat one will never die! (http://www.kfat.com/)
Old 03-09-2012, 9:31 PM
Yes, any scanner is capable of doing that with software. Or you can use FTO on Uniden and just send out the audio.
Old 03-09-2012, 9:40 PM
I know this and I have two 996XT. I am wanting to do a secondary paging system that sends out emails.
(402) 937-8578
Old 03-09-2012, 9:56 PM
Check out eDispatches | Emergency Dispatch Notification Services
Just needs a dedicated PC and scanner hooked into the audio in port. A few agencies that use are pleased with its performance.
JJ
Old 03-09-2012, 9:59 PM
JJ
I am doing this right now but with two tone software. But there are a lot of false trips
(402) 937-8578
Old 03-09-2012, 10:04 PM
Sounds like you need a better quality signal in, or may e your tones are incorrect?
Old 03-09-2012, 10:08 PM
Well they use the same frequency for dispatch and tac. So some how the it trips the decoder.
(402) 937-8578
Old 03-10-2012, 6:03 AM
SteveC0625's Avatar
If you just need a single channel receiver with Quick Call II capability, almost any alerting pager like the Minitors should work. You might need an attenuating patch cord between the pager and the PC. Minitors are all over Ebay and prices are dropping on the II's, III's, and IV's. The II's in particular are quite inexpensive now, and you can pick up a charger/amp cheap, too. The charger/amp is a good choice for your application because it has an antenna connection and an audio out connection. This guy refurbs Minitor II's and has a large stock of crystals and tone reeds: Home Page
The Veetronix receiver might be a good choice, too. Comm Products
Even a Plectron will work. This guy repairs, refurbishes, and sells them. Home
Old 05-10-2012, 12:22 AM
cmdcomm's Avatar
the product at Command Communications Command Communications has this product
