Those all appear to be radios for the 1980's, most don't appear to support narrow band channels, some do depending on the model. Likely on this site you will either get people tell you they were the best radios ever made, or they are junk, the opinions seem to swing wildly here. Based on the age of these, it would take some work to make them useable on the amateur radio bands, which is likely the only legal place they could be used. Since you are asking about these, I'd say dump them and get a few bucks if you can. They are not worth much unless you can find someone that really needs them for the parts. There are a number of newer model radios out there on the used market that are easier to program and get parts for. If you have all the accessories for these and it's all in good shape, you may be $25 each for them. You can get newer Motorola radios for $50 now.
GE Phonenix-SX & GE Phonenix-SX w/ Scan These are either VHF or UHF, and require a programmer. Some can be converted for Amateur use.
Yaesu FTL-7002 is a 450MHz to 470MHz 25 watt dash mount radio. 16 channels. Appears to need a special programmer interface.
Midland 70-1340b is a 150MHz to 174MHz 40 watt dash mount radio. 22 channels.
