BK portable radios made into a repeater
WQOQ867
Northwest Montana
Can someone tell me how to make a portable UHF repeater using old Bendix King Portables? Im told its rather easy to do.
mancow
N.E. Kansas
http://www.repeater-builder.com/bendix-king/pdf/bk-repeater.pdf
This guy has a decent writeup already done but you are talking UHF. The UHF are based on the EPH style board layout. The board examples in the file won't correlate at all at a component level. The LPU/EPU/EPH series did away with the lower header pin layout in exchange for a systems board in the front cover and the CPU was moved to the center RX board area. The good thing is the side pins are all still the same so audio and mic and power can be tapped there just the same.
More info here.
http://www.repeater-builder.com/bendix-king/b-k-index.html
You will need to pull a COR signal somehow and often the RX LED is used for that but there are other locations.
mancow
N.E. Kansas
WTF did you just quote my entire post?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
He copied it because he's a spammer who is trying to get past the 5 post moderation rule.
He copies other peoples posts which make them look legit when the Moderation Queue is worked.
He's been banned now.
