Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Industry Discussion
Industry Discussion General discussion forum for commercial and professional radio technologies. This includes manufacturers not listed below.
View Poll Results: Which radio do you like the best?
Motorola APX7000 11 55.00%
Harris Unity XG-100P 9 45.00%
Voters: 20. You may not vote on this poll
Old 02-01-2014, 9:57 PM
KampingAnthony1AolCo's Avatar
Default Motorola APX7000 or Harris Unity XG-100P
Hello I wanted to see peoples opinions on which radio they like the best and you can give your options on the radios also if you want. You can say why you like that radio and why you choose it.
Anthony Lee
Only email me if you are a Moderator or Admin.
Motorola APX7000 UHF/700-800
Motorola HT1250LS+ UHF 403-470MHz
Old 02-02-2014, 5:04 AM
If you have no need to connect to a 3600 baud Motorola Smartzone/Smartnet then by all means there is no real choice except the Harris due to it covering all of the bands (VHF/UHF/700-800) that a single APX is not capable of. Until Motorola shows up with a true radio that covers all the bands this really isn't a viable poll.
Personally I use the APX because I have a need to connect to multiple SmartZone/Smartnet systems so I would be biased based on that point as the Unity is incapable of doing this particular system type even though I have tried the Harris and it is a very impressive radio, but my exposure was only for a few hours and I have never tried the Thales Liberty radio that is also available but is not in the poll.
Old 02-02-2014, 2:37 PM
One big point to remember that any of these multi band radios has a major down side. That is yes, they can scan and listen to multiple bands. The problem comes up if your at a multi agency incident and the agencies are on multiple bands. You hear the first RF signal that shows on your receiver. If there is traffic on another band at the same time, your out of luck.
What your holding in your hand is a very expensive scanner. First signal captures the receiver and you loose everything else until that first signal goes away and the scan starts up again in the receiver.
If the reason your going to these radios is for the multi band operation, so be it. But you might be better off with 2 radios when the incident is using more than one band for the different agencies. The other solution is to use a mobile command vehicle that has multiple radios and can patch them together through a gateway. That way everyone can hear all the channels.
Jim
Old 02-02-2014, 5:53 PM
DisasterGuy's Avatar
I use both and honestly each fits different applications well. Regarding it as a "scanner", that is NOT the reason to use a multiband public safety radio.
Old 02-02-2014, 6:17 PM
I have the APX, Unity and Liberty. They all have their advantages and I have always traditionally been a MOT guy. I will say, however, I have been carrying the Unity more often. The audio is the best of all 3 radios, the display is the best of the three and the fact that it is tri-band is a plus. MOT and Thales are much more friendly about providing firmware upgrades, etc. The Unity is solid, has good battery life. The programming software is very different (the "green" guys and their mission plans are to blame). The one advantage of the APX is that there is so much more accessories than the other two. MOT and Thales are much more consumer/HAM friendly... Harris sees a one unit sale as a possible competitor purchase or practically a terrorist... MOT and Thales are VERY ham friendly.
If I could only have one radio, it would be the Unity, however.
Old 03-10-2014, 10:01 AM
f40ph's Avatar
Just trying to learn more about multi-band radios:
So the Unity can NOT perform MOT P25 trunking - correct? If that's the case, agencies that are using it are only using conventional? or does it do another type of trunking?
<thanks for educating me>
Old 03-10-2014, 11:50 AM
The Unity is incapable of doing the 3600 CC Motorola trunking system.
There is no "Moto P25 trunking". P25 Trunking is a conventional and trunking standard that numerous manufacturers agreed to build to that includes Motorola and Harris.
Old 03-10-2014, 11:57 AM
f40ph's Avatar
Thanks for the additional.
My local agency is converting from an 800mhz Moto Smartnet type II to a 7.x P25 system. Is that something Unity would handle or is this the 3600 CC Moto you're referring to?
Old 03-10-2014, 12:27 PM
A P25 system is a 9600bps control channel, that is either P25 phase 1 or phase 2. A 3600bps control channel is Motorola type 2 smart net/zone that can have Analogue and digital(P25 CAI)
Interoperatablity is not a technology it is an attitude!!!
Old 03-10-2014, 3:17 PM
Default Like the Unity also.
Like radiomankc, I have owned all three radios: Unity, Liberty and APX and seem to carry the Unity more also.
At first it seemed very foreign to program, but luckily I had just retired from the "green" world and had used PRC-148's and 152's, 117's for quite some time.
My first thought on the three radios were as follows:
APX-7000, why do I have to choose 2 bands? For this price, I want three bands.
Thales Liberty, heavy and feels like a commercial MBITR, but has a full keypad.
Unity, I like the large display, but this thing feels like it will break the first time I drop it. The plastic covers on the top and front display stayed on for the first 6 months or so as I felt it was adding some protection to the radio. After the first drop on concrete, I felt better. One small scratch, a splash in the water, and everything still works. (I work on ships near water, so IS rated and water resistance are a must.)
Now, I have an older VHF Astro Saber, and a Harris Unity that I use very often. The others were sold off, traded for other models and not used very much.
As for ham radio use, Motorola is very good as once you learn to use the CPS, it doesn't change very much.
The idea of "mission plans" in the Unity, drives me nuts after programming a pile of Motorola handhelds. But once, you do it a few times, it gets easier.
With piles of Motorola equipment on auction sites, that is what I recommend for amateur radio use.
If you need it for work, have your employer pay for it and buy new gear. In my case I made a deal with the local radio vendor on a Harris Unity that I use for fun and work.
Old 03-22-2014, 3:15 PM
Has anyone purchased any brand new multiband radio with technical issues directly from the factory? (Did happen to me)
Old 03-22-2014, 3:17 PM
Has anyone purchased any brand new multiband radio with technical issues directly from the factory? Which did happen to me.
Old 03-22-2014, 3:22 PM
How many zones (total) does the Harris Unity have? I have searched the technical spec sheet, but can't find it.
Old 03-22-2014, 4:46 PM
Harris radios don't use zones in the same way that motorola does. You have systems, groups and in the case of the Unity series you also have zones and mission plans. The Unity portable supports 1,250 channels/talkgroups per mission plan. The Unity (like any Harris radio) requires that all systems (analog/P25 Conventional/P25 systems) in their own "system". These systems appear in the radio the same way as a zone would within a motorola radio. With that said it also allows you to create zones above and beyond the systems as a way to mix systems into a single ramp. I do not believe that the number of zones is limited. Since it also hold mission plans (multiple personality files) you can have a total of 12,500 channels/talkgroups per radio.
I have been playing with the APX7000 VHF/800 quite a bit the last few weeks and still prefer the Unity. What I can say is that audio is louder on the APX and the audio also has more bass.
Old 03-22-2014, 9:08 PM
This link might help:Harris XG-100P Channels per zone. It is under the Harris forum.
Anthony Lee
Old 03-24-2014, 11:54 PM
Just like others here, I own all three. Each has advantages and disadvantages. I carry the APX most as I only need 2 bands most of the time , and the Unity second. Depends on the mission and if I need 800. The Liberty spends it's time on a shelf and is recharged every month. I like the one button push scan channel temp delete on the APX & Liberty....the Unity you have to go in the menu and delete. The APX you can store GPS waypoints, the Unity only shows GPS info. where the APX does not. APX has the best audio. APX & Liberty will scan anything in the radio where the Unity will only scan systems. (Harris is working on this) APX & Liberty are more rugged than the Unity. APX R version and the Liberty are watertight to 6' for 2 hrs the Unity only 3' for 30min. The Liberty is like holding a brick, the Unity is like a comfortable brick, the APX will fit nicely in your back pocket. APX is the easiest to get parts for. The APX & Liberty will do true multi mode receive the Unity will not. Unity has squelch crash on analog PL channels. Encryption on both the APX & Liberty is more user & programer friendly. Unity has GPS for the time base, the others you have to set the clock. Unity has cool RSSI meter the others do not. I'll stop here as this should give a general idea of each.......
Old 03-25-2014, 12:21 AM
For the Unity, just program a side button for nuisance delete - no need to go into a menu.
Old 03-26-2014, 7:07 AM
Thunderknight,
Have you actually tried this or are you just guessing? We tried the side button programmed for nuisance delete. Our radios won't do it with the button programmed for it. If your radio does work what is the tick to programing it it beyond just programming the button function?
Old 03-26-2014, 7:31 AM
Thunderknight,
Actually, bottom side button using firmware 4.3.11 on an analog channel. I don't think there is any trick otherwise.
You are not actually selected on the channel when you are deleting it, right? Just let the normal scan scan from a different channel, and when it lands on the busy nuisance channel, hit the button and it drops it from the scan list. It comes back into the scan list if you cycle power or mission plans.
Old 03-27-2014, 6:58 AM
Thunderknight,
Sorry for questioning you, but you know how some of these online threads can get.
The radios are running XGPRO1A38, RPM is current. Programmed as you suggested....button just gives a beep. Perhaps there is a bug in this firmware version that will be corrected the next time around? Also this firmware does not do Type 99 decode. The scan has bugs where it locks up scanning that Harris knows about and is currently working on a fix.
