KVL question
poltergeisty
Truth is a force of nature
Banned
RLG, Fly heading 053, intercept 315 DVV
I can't post in the tavern due to the mods otherwise I would have posted this in the Off topic Wireless sub forum. I have a question about KVLs (Key variable Loaders) and just want the low down on why you need to use a separate piece of equipment to upload an encryption key to a radio? Why can't you just use the CPS (software that programs the radio) to add an encryption key? I guess it might have something to do with FIPS, but without going through technical jargon and such I just want a simple answer. I have looked though Google and have read patents and other sites and couldn't find my answer. However, I did find a really nice PDF on encryption that was created by a user over at batlabs back in 2006. I can't find the original link, but I uploaded the PDF to my Dropbox. https://www.dropbox.com/s/yihtzvk371j75uv/encryption.pdf?dl=0
TIA for answers on KVLs. :)
n0nhp
Grand Junction
Physical Security.
As we all know, software and the hardware to program radios can be found without much problem. An entity that uses a KVL will have that piece of hardware (it is very small) entrusted to only certain personnel. The installer, the mechanic and the bench tech are not going to have physical access to the device. They also can not grab the "code plug" and drop it on a thumb drive.
They were originally designed that way for the three letter agencies and just like computer security, no physical access = security.
Bruce
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Thread moved to Industry Discussion since this has nothing to do with Colorado.
Lower forms of encryption such as Motorola's ADP can be programmed through CPS.
RAD909
Why not use software vs a KVL....answer is
In answer to your question: "Why can't you just use the CPS (software that programs the radio) to add an encryption key?"
"Keyloader" (KVL - Key Variable Loader) is used in the more advanced forms of encryption; DEA and AES. DES and AES encryption is used by law enforcement, intelligence agencies, military operations, etc.
Bottom line is, software is not used because there is no possible way to control the distribution and use of a software program. Since access to the KVL device constitutes potential access to the entire system, these devices are not available to the general public, and are closely guarded at radio shops, or government agencies, where they reside. The manufacturers of radios using KVLs usually require some assurance and tracking of where the KVL devices are being used and what security is in place at the location of use. It's all about security and access.
sfd119
I can buy a KVL on ebay...
Just 'cuz you have a KVL, doesn't mean you instantly get the key. The reason for a KVL is I can place it in a safe and control who has access to that device. That way, I know how is getting the Encryption key and when.
All about security.
mancow
N.E. Kansas
A racal25 will allow programming of des and aes via the software. Good luck finding batteries.
radioman2001
New York North Carolina and all points in between
The KVL is a civilian version of a military key fill device called a KY, and there are many versions that are used. You sign for you keys from the key authority,(it could be anyone from the base commander to the local radio shop) and then they are loaded into your keyfill device. You are, or more correctly your keyfill is used to disseminate these keys in your command, and you the signor are responsible for those keys and their dissemination. All traceable back to you and your fill device, which you are responsible to keep safe.
The civilian KVL can generate those keys that you put in. They have to follow a specific plan usually based on HEX coding so there are no duplicate sequential numbers or letters, as that can cause problems during decoding. Anybody can create keys, just not the ones you don't own unless you want to spend a LOT of time running random numbers to come up with someone else's keys. From there they can be disseminated and or transfered into another KVL or the end radio or device.
Again just because you have a KVL your not going to be able to load someone else's key unless you know the numbers and or letters.
