I am working on a new project and I am kind of stuck. I am seeking to transmit audio through a low powered transmitter and monitor on my portable. I have found several devices but they don't work for my required frequency range and are likely not FCC approved.
Band: 467-469MHz. Yes I am licensed on several UHF frequencies.
Channel options: 1 channel with CTCSS capability, both user programmable
Output power: 500mW - 1W, just need line of sight for several hundred feet
Audio: Any standard audio connector such as 3.5mm or XLR
Cycle: Continuous transmit from several minutes to a couple hours at a time
Power: Tapped to an external battery, fused
Any ideas would be appreciated.
