vehicle repeaters
whirley1
wichita, ks
vhf vrs for portables
I just bought a few radios, sirens and vrs and I have several ht600's. when I put these systems together, will the ht600s work with the vrs, or do I need to upgrade the ht's?
kayn1n32008
ØÆSØ
Sector 001
What radio service is this going to be used on? What country are you in?
whirley1
wichita, ks
the radios, sirens and vrs's are already programed from the previous owners so I know they work together so I just need to know is about the ht600's and working on simplex. Thanks
kayn1n32008
ØÆSØ
Sector 001
Again, what service is this equipment going to be used in?
kayn1n32008
ØÆSØ
Sector 001
any chance of getting a copy of the manual for my repeater?
If it's going to be used on any service other than ham band, you will need new portables, the HT-600 is not narrow band compliant. If it's part 90 service, you MUST be using 2.5KHz deviation ONLY. 5KHz is no longer allowed on VHF and UHF, unless you operate on T-Band(470-520MHz)
kayn1n32008
ØÆSØ
Sector 001
i have syntor x9000's high band 150-174 and my ht600's are the same. won't these work together? Thanks again
They can be made to work together, BUT it will require some engineering and LOTS of frequency separation and filtering to make it work.
kayn1n32008
ØÆSØ
Sector 001
so your telling me, I need new uhf portables, right. Thanks and sorry for being slow to understand
No but it needs some one with experience in filter design to help you to be able to use a VHF mobile with a VHF extender.
i'm told simplex does not require a license. I'm I correct?
100% wrong. Outside of MURS EVERY frequency on the VHF band requires a license
kayn1n32008
ØÆSØ
Sector 001
The Syntor is not narrow band compliant, and there for is not allowed to be used on part 90 frequencies any more.
With proper antenna separation, and filtering they can be made to work together, BUT none of your gear can be used on VHF except for in the ham band, ALL part-90 requires Narrow band compliant gear, of which your equipment is not. I also now question if the VRS is narrow band compliant as well.
whirley1
wichita, ks
just curious, if narrowband radios and only allowed on the air, why are there so many old radios being sold and used all over the country? why aren't the old radios forbidden to be sold here in the states
KevinC
Big Dog...celebrating 10 years of abuse!
Super Moderator
Home
Some "old" radios are narrowband compliant.
or
They may be being used in the Amateur Radio Service
or
The buyers may not care about breaking the law
Take your choice, but your blanket question can't easily be answered.
