N0BDW
Hi folks,
My FD is purchasing a new Chief's truck and as the person in charge of communications I'm responsible for finding a radio solution that will meet our needs. The truck will be a 2015 Chevy Tahoe and the rear will be used as a command center.
Requirements:
* Dual VHF heads
* Dual low band (46Mhz) heads
* Ability to communicate on this system: Genesee, Monroe, Ontario, Orleans Counties Public Safety Trunking System, Regional, New York - Scanner Frequencies (specificially Ontario County NY)
* MDC1200 identifier transmit and receive on the VHF and low band -- and whatever might be needed for the Ontario system
* In house ability to program
Notes:
We currently have a low band CDM1250 that we can use for one of the low band heads.
We're not tied to Motorola, but have strong preference there (majority of our radios are Motorola)
We have the programming capabilities for Waris series Motorola radios
The communications with the Ontario County system either needs dual heads or to be in the form of a portable. If a mobile, it'd be nice if we could cover both that system and VHF with a single radio, unless cost prohibitive. If we cover this with a portable, we still need dual head VHF in the truck
Both the VHF and low band only *need* to do analog. Any other modes they can do for future compatibility are bonus.
I understand there is a dual head kit for the CDM series that allows it to have multiple heads but this is not an acceptable solution. I've read about a number of issues with it and we need this system to be stable and easily programmable. I would rather buy a 2nd radio.
I really don't know much about the Ontario system, and they are only one town over from us so it is not uncommon for us to use them or be used by them for mutual aid. I know they are using Harris portables for almost everything.
Not a requirement but it might be nice to be able to cross band repeat between VHF analog and the Ontario system. We have all VHF analog portables, and that way if the Chief's vehicle is on scene every FF can essentially be on the same fireground channel. This may be cost prohibitive. We currently do this between low band and VHF using a Motorola "RICK" (like HLN3333B HLN3333 - Motorola RICK - REPEATER INTERFACE COMM KIT - ShopWiscomm) between a VHF CDM1250 and a low band CDM750.
Would appreciate any suggestions.
Requirements:
* Dual VHF heads
Notes:
