Recording with an HP-1, HP-2, BCD536HP or BCD436HP. Other scanners record but the data is less easy to handle away from the scanner
Recording only takes place when a transmission rakes place. Recordings are in WAV format.
It records the specific date and time of the transmissions as well as the talkgroup or frequency along with the audio itself and puts these into a folder or folders for the incident.
All records on to mini SDHC cards on the scanner which can be pulled from the scanner and copied easily or copied via USB from scanner to PC.
I copy these folders to PC and then use an application called Media Monkey to play back because each time a microphone is keyed, it shows the date, time, system, department, talkgroup, and length of transmission. Any of these individual transmissions is a separate .WAV file that can be copied, distributed, emailed, or whatever.
BCD536HP/HP-1E/HP-2E/BCD996XT/BCD396XT(2)/BCD996T/PSR-800/PRO-96 +
