EF Johnson 5100
RadioGuy3007
Hello,
I programmed my EF Johnson for some P25 Frequencies and the transmit disabled. However the radio always mutes the transmission unless I keep it on that channel and keep it in monitoring mode. How can I fix this?
box23
State of Superior
Depending on how the channel is setup and version of firmware/radio, you may have to set to Digital CSQ in the software. The early 5100's do not ignore the talkgroup information and won't unmute if all the information doesn't match.
Other radios tend to ignore the talkgroup information when operating in "normal" digital mode, so only the NAC is required. Only when set to use talkgroups do they following that information.
The Digital CSQ setting is entirely separate than the special NAC F7E in the 5100's. Using Digital CSQ will allow any P25 signal to be received regardless of talkgroup or NAC.
