6DIAW
Hello all. First time poster long time reader.
I have a DMR radio and I want to be able to MONITOR ( well, as much as possible) TRBO connect plus or CAP +.
I have the CPS software and have plugged in the freqs for the system and set up a RX group for all the TG's I would like to listen to and placed that rx group in each frequency for the system( making seperate channels) then making a scan list. My train of thought is analogous to listening to an analog trunked system (hearing parts of the transmission based on what frequency channel the radio is on). This actually works with P25 trunk as well, but pointless if you have a trunktracker radio.
So in theory, If I have the right CC, Slot and TG (as listed on this site), I should be able to listen to an active TG that lands on a frequency that is programmed in. Or just have it on scan and be able to quazi follow the TG through the frequencies..
Can anyone point out if this will work or not or if I am missing something in order to make it work?
I had my fun with PC based monitoring with DSD etc and want to have it mobile.
