do encrypted radio systems for states and municipalities lose the encryption key and revert to in the clear or does this only happen to federal systems? thanks
. It does happen on occasion. My local pd has a couple squads that transmit in the clear most of the time, but I don't think they realize it. They probably are so used to hearing the beep, indicating encrypt that they don't notice when its not there. I like it when their radios lose the key. . 73, n9zasdo encrypted radio systems for states and municipalities lose the encryption key and revert to in the clear or does this only happen to federal systems? thanks
Dont they have to also pay for the lease of the Encryption ........
The encryption sends out a carrier with no modulation on your scanner...you will see the channel come up but thats it! You can buy a motorola that will hear the encryption but all kind of letters must be given to the radio programer even though its on receive only! A person can buy one at one shop with receive only and go to another shop and have it changed!
They are responsible for keeping up with the radios and encryption modules and they stop by our shop if they need to be re-keyed or if the encryption modules need to be moved from one radio to another.
Why don't they do over the air re-keying?
Should an agency make it public that they are going to be using encryption?
So affected parties can prepare.Why? When encryption is enabled, it is pretty obvious.
Over the air rekeying is not as common as people think. Part of keeping track of radios for a larger organization is to put physical hands on it once in a while. This could be to change programming, rekey comsec, swap batteries, hook the radio up to test equipment for periodic maintenance and so forth.
One group I dealth with, all Motorola radios were touched for re-keys. All Harris PRC-152's were done over the air. Anybody not re-keyed had to come to me if they missed that re-key. There were reasons for both of these situations.
. You may have ended up with a bricked saber is all. 73, n9zasMany years back I was in Miami for a work project and was carrying a Motorola Systems Saber (ham GMRS stuff). I was dressed business casual and walking from my car into the hotel right by the Miami Intl Airport. As I approached I noticed a bunch of federal looking guys in suits and a table set up right inside by the side door with radios and keyloaders. One of them approached me and actually asked if I "needed my radio rekeyed". I told, him "no thanks" I am all set! I wonder what would have happened if I had let them go ahead load a key!
It's not uncommon for agencies to announce such plans.
Yep - PS system operators implement encryption without telling neighbouring agencies or the media all the time. Maybe in your world...Who would be affected ? Monitors or users ?
Monitors ? Who cares, not the problem of the system owner/operators :roll:
