OK, I have two ef Johnson ascend ES radios.
One is a model 3 7/800mhz radio and one is a model 1 380-470mhz.
I figured I'd just enable features and swap housings as I want to use the uhf. When I install the housing from the 7/800mhz radio to the uhf I get a bad band error. If I use tuner it says 7/800mhz.... That means the data is in the housing not the radio with the RF Board and ucm. Any help would be appreciated.... I have pcc, tuner and issue tho I don't think PcIssue is needed here as features are already set.
Please help me out?
Please help me out?
