Help...
Iandc_qa
Good day gurus. I want to know the exact model of this radio and if it is possible to connect a headset to it. We have a small office and this sucker is too loud. Our set up would be this base radio with possibly a plantronics ptt headset. The problem is that we are clueless as to what hardware we could use. We are also using eads thr 880i tetra radios if that helps.
wyShack
Campbell County, Wyoming
check the rear panel-you will likely find a nameplate with the information you are looking for. You may also find a external speaker and or headphone jack. A small mirror may be used to see the back if it is held in place by a mount or wires. Another place to check would be the stickers now covered by beards-nice touch. After you find some info get back or use Google.
Good luck -hope the above helps
Iandc_qa
The beards were deliberately placed by me. Asset tags for Qatar Red Crescent. Will try the mirrors. Though i highly doubt that i can see what's written. Thanks.
Golay
Peek a Boo
Looking at the picture, this don't appear to be difficult to pull forward and get a good look. Like wyShack said, it could be on the back, it could be on the bottom.
Question that crosses my mind is this: If those are asset tags, then I'm thinking your using a computerized material management system (or something along those lines) that would describe the make and model of each asset number.
