Radios That Do Cap+ Or Con+ Other Than Motorola?
CanesFan95
FL
Are there any other brands other than Motorola to get a radio that will do Cap+ Or Con+ trunking? There's a lot of DMR radios, but none of em seem to do trunking. Why?
KevinC
Big Dog...celebrating 10 years of abuse!
Super Moderator
Home
Cap+ and Con+ are proprietary. They "might" license them to someone else, but I doubt it.
Lots of other DMR radios do trunking, just not Cap+ or Con+. Tier 3 is the DMR trunking standard.
CanesFan95
FL
That's a bummer. I thought DMR was an open thing where greedy companies can't patent it.
kayn1n32008
ØÆSØ
Sector 001
No other brands do Con+ or Cap+.
There are a bunch of manufacturers that do Tier 3(Cap+ and Con+ are NOT tier 3 compatible) Tait, Hytera, and Simoco are three that come to mind that do Tier 3 trunking. Motorola Capacity Max(I think it is) can be tier 3 compatible.
CanesFan95
FL
Then why are so many customers buying Cap+ and Con+? They are falling right into Motorola's monopoly. Doesn't that defeat the whole point of an open standard with fair competition?
kayn1n32008
ØÆSØ
Sector 001
People fall for the brand name. I am working for a client that has a Motorola linked Con+ system with XPR6550 and XPR4550 subscribers. Sadly they could have saved a boatload and gone Simoco or Tait, and got a much better product in the end.
Sadly Motorola is circling the drain, hopefully Hytera and Tait put them out to pasture in the DMR market.
RayAir
About 8 out of 10 DMR systems in my area are Motorola. The others are Hytera and use conventional repeater pseudo-trunk.
Hytera also offers eXtended Pseudo Trunk (similar to Capacity Plus) and tier 3 trunking.
I set up a local Hytera repeater with Pseudo Trunk and AES256. The only feature it lacks is authentication. XPT systems have authentication options and in the latest firmware I think conventional repeaters now have an option similar to RAS.
Hopefully Hytera gets a much larger footprint in NA.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Does TAIT not do those they claim on their website interopabilty
For P25 they are interoperable with Astro 25. DMR they stay to the standards for the most part.
I've yet to hear of a working Tier III solution from Hytera. It's not the out of the box solution Hytera claims. I always liked the way Simoco approached system access in Tier II as it must've been designed by an IP network engineer. Gives you the option to whitelist or blacklist IDs.
Motorola is the name brand. The old addage, no one ever got fired for buying Motorola (mostly true). Capacity Plus was a great idea when Motorola owned the US DMR market as it made sense for individual businesses to have a scalable pseudo-trunk. Connect Plus was and is their high end trunking format for DMR I'd is really only practical for airtime systems. I think Capacity Max was released in the US as they felt they were loosing opportunities from the Tier III vendors but it sits somewhere between the two others. Still really geared at airtime or utilities though.
kayn1n32008
ØÆSØ
Sector 001
Not just in the US. More and more system buyers are requiring a standards based network.
Manitoba Hydro bought a DMR system. Motorola was disqualified from bidding(Tait won the contract) because they did not have a tier 3 compliant option at the time. I have heard they have been disqualified from bidding on other DMR networks in other countries as well.
