recommendations for mobile repeater
paulears
Lowestoft - UK
I've got a number of systems I manage and hire out, and for a job starting in the summer I need to equip a small van with a repeater for on site coverage on UHF. Most of my kit is Kenwood - lots of analogue and a smaller amount of Nexedge. This one will be very simple - low power - no more than 5W or so, separate antennae so no duplexer, 12V only operation - but modest in size. I do have a TYT TR-50 that I'm not that impressed with, but that size would be great, although I can go a little larger. It's unlikely I'll recover the purchase price on the job, so although I'd like something 'clever', it's really not necessary.
Does anyone have an favourite smallish repeaters they'd recommend?
Thanks Paul
jim202
New Orleans region
Thanks Paul
You can take a look at this site: Pyramid Communications Home - Pyramid Communications
They have some nice equipment that can be configured for many uses. They are not rock bottom in price, but they do work well and the people there are good to work with.
Since you have NXDN radios, are you interested in a repeater that will do both analog and NXDN?
An NXR-800 will do 5 watts. It's one rack unit, so easy to stick in a rack mount or rack mount case. It's got separate TX and RX antenna ports. Runs off 12 volts.
Trouble is, the NXR-800 has been replaced by the NXR-5800, which is probably more than what you want. None the less, there may still be some new NXR-800's out there at dealers or on the used market.
NXR-810 is a 25 to 50 watt unit, and be turned down to 5 watts if you want. List price is around 2K.
paulears
Lowestoft - UK
Thanks Jim - not a make I'd heard of here in the UK, and somewhat pricey, but thanks for the info. Size wise, they fit the bill though!
Mmckenna - I do have an 810 - which is a bit too big. maybe the 1U version could be squeezed in vertically, if I make up some brackets?
Project25_MASTR
Millennial Graying OBT Guy
Texas
Icom FR8000 if memory serves correctly. Should be a full duplex unit in a mobile former factor (similar to that of the R1225).
Of course, Simoco has the SRM9000 series mobiles which can be turned into a P25 repeater (or analog) if that functionality is needed.
Sent from my SM-T713 using Tapatalk
ramal121
Lots and lots of watts
Calif Whine Country
NXR-810 can be removed from its rack mount frame. Cuts the width in half. Is that still too big? You'd have to cook up an alternate mounting scheme though.
paulears
Lowestoft - UK
Really? In that case, problem solved because I can live with the height, just 19" wide was too much for the space. I can easily make up mounting hardware - brilliant!
Your_account
Banned
.AT
Do you check what a licence cost for you when use a repeater?
Here in Austria a Radio System cost x10 more than a DECT System or Cellphone Contract.
Firebuff880
Boynton Beach, FL
As suggested the NXR-800 if you want the digital NXDN, if you just want Analog or are looking at DMR then the Motorola SLR-5700 in a 19" or the SLR-1000 (Not sure if it is shipping yet) in the IP67 "pool" case. The 1000 is a 5700 repacked max 10 Watts.
kayn1n32008
ØÆSØ
Sector 001
I need to equip a small van with a repeater for on site coverage on UHF... I do have a TYT TR-50 that I'm not that impressed with, but that size would be great, although I can go a little larger... It's unlikely I'll recover the purchase price on the job,
Thanks Paul
Do you mean a HYTERA TR-50? if so, please do not roll it in with Tytera junk.
If you have a mobile duplexer, then you should be set. even with a crappy mobile duplexer you should not have anywhere near 3dB of loss , unless you are using a pair that is less than 5MHz apart. I would not mess with trying to get dual antennas to work. Rather than spend money on a new repeater, use what you already have on hand, so you don't have to lose money on the venture
paulears
Lowestoft - UK
Sorry - meant HYT, but to be fair, this isn't the most reliable repeater being one of those designs where you take two handhelds and bung them in a case, tag the links onto the pcb, and add a power supply. I'm not keen to use a duplexers as they really don't like vibration, and two antennas seem the sensible way. It's looking like I might be able to get a Kenwood 810 into the van, if I bolt it to the bulkhead at the bottom, as it angles, and I have a few extra inches at floor level - Right angle connectors should do the trick. It looks like the van roof will need a few extra holes for this one. There are three at the moment already.
kayn1n32008
ØÆSØ
Sector 001
With out adequate vertical separation dual antennas will not work on a van, you will not get enough horizontal separation. Mobile duplexes are just that, duplexes mentioned for a mobile environment
Sent from my SM-G870W using Tapatalk
paulears
Lowestoft - UK
Really - I've rarely had issues doing this for years, as have the Police and numerous other organisations. UHF back-to back was a feature on loads of Police vehicles, and the broadcast OB vehicles I work with often have the similar system for their local talkback. There is certainly desense, but 6MHz or more split, it doesn't seem to have been a major headache. Vertical stacking is clearly better practice, and common on towers, but is there really a problem with limited area coverage?
kayn1n32008
ØÆSØ
Sector 001
All depends on terrain, and area you need to cover. Most modern receivers in portables/mobiles are pretty broad banded, not like the days of mitrek mobiles with helical preselectors. I would expect lots of desense, 6MHz is not a lot of frequency separation if trying to use dual antennas with only horizontal separation.
Project25_MASTR
Texas
There is actually a formula for figuring out...but Repeater-Builder has the guesstiment charts that Motorola built years ago for figuring out needed separation.
paulears
Lowestoft - UK
Quick report - so far the results are NOT encouraging. Kayn's prediction appear to be correct and the separation is not sufficient. In fact, so poor that I need a spacing of 11MHz before I get a system that would be usable. I had hoped that 8MHz would be acceptable but the repeater even on low power desenses the receiver far too much. I'm now on plan B. Kenwood repeater in a 4U rack, with a small fixed station duplexer, wrapped in foam in the 2U empty space, and a single antenna. Takes up far too much space, but appears to be a working solution.
