Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Industry Discussion
Industry Discussion - General discussion forum for commercial and professional radio technologies. This includes manufacturers not listed below.
Old 02-13-2018, 2:08 AM
Rlahey's Avatar
Default Wilson Cellular Extender
Recently I purchased https://www.wilsonamplifiers.com/web...er-kit-470108/ from ebay...
Im looking at an NMO style antenna... I see that the included antenna covers 6+ bands. Most of the Laird/PCTEL and other commercial antennas are "dual band". I would rather get a quality antenna rather than the one supplied by Wilson but I having trouble finding that I need. Im having trouble finding anything other than a dual band cellular antenna...
Thoughts?
Old 02-13-2018, 8:08 AM
mmckenna's Avatar
Who is your cellular carrier? The stock antennas are designed to cover everybody/everywhere. In reality, your carrier may only be using 2 or 3 bands.
Old 02-13-2018, 12:18 PM
Rlahey's Avatar
Verizon
Old 02-13-2018, 1:10 PM
mmckenna's Avatar
Verizon and you are in NS?
https://www.wilsonamplifiers.com/fre...es-by-provider
Keep in mind that most of the cellular antennas are -very- broad banded.
Old 02-13-2018, 5:00 PM
Rlahey's Avatar
Chart was very helpful I need an antenna with 4G capability which is 700mhz- which means I need a multi band antenna in the end. Thanks for the help
Old 02-13-2018, 5:32 PM
jtech48's Avatar
Laird does make a multiband 3G/4G antenna, one of them being the phantom TRA6927M3NB-001. Based on the spec sheet it covers all the bands you need with Verizon.
In Flying, Carelessness And Overconfidence Are Usually Far More Dangerous Than Deliberately Accepted Risks
WQOE503
Old 02-14-2018, 2:16 PM
"Chart was very helpful I need an antenna with 4G capability "
Heads up. Because "4G" in the US industry means "3G with enhanced backbone speeds" it is NOT the same as the "LTE" bands, which are called "4G" in the rest of the world.
There was a huge kerfluffle over this about three of four years ago, when a class action lawsuit was being brought against the US cellular industry for deceptive misuse of the term "4G". That was only dropped when the ITU passed a special ruling, allowing the US carriers to continue the deceptive misuse of the "4G" term. And it continues that way today.
4G? In the US or with US equipment? Ain't the same as 4G-LTE.
Old 02-14-2018, 3:56 PM
For those that check out the Chart that are in Canada, Telus no longer supports CDMA. They also utilize much more spectrum than is shown on that chart. There is also likely other spectrum errors on that chart, for Canadian providers.
Interoperatablity is not a technology, it is an attitude!!!
Old 02-14-2018, 3:59 PM
MikeOxlong's Avatar
Forums Manager/Global DB Admin/Commie
The chart is from 2014.
Mike.
Old 02-14-2018, 4:20 PM
Oh, it gets worse. Verizon also hasn't supported CDMA in years. They migrated to CDMA2000 which is a hybrid, much as true LTE is neither CDMA nor TDMA but a hybrid of both.
Many of the carriers have been quietly dropping provision for everything but their latest protocol, getting prepared to clear racks out of the cell towers and replace them with 4G-LTE and the upcoming 5G as soon as they can figure out an equipment standard for that.
"If they move their lips they're lying" applies.
Old 02-16-2018, 12:41 AM
Rlahey's Avatar
Regardless if its fancy 3G of actual 4G... Verizon uses 700mhz for data. Most dualband cellular antennas dont only go as low as 850mhz. I think Im going to go with a multiband antenna to be safe.
Old 02-16-2018, 4:37 PM
alcahuete's Avatar
They do but that's usually their last choice, if you're getting a poor signal and need long distance. The preferred bands are in the 1700-2100 MHz range.
