I have a Relm KNG-P400, and I am trying to receive (Rx only) a " implicit " Phase I trunked system.
I have successfully monitored other non-implicit trunked systems with this radio, with no problems. However, the system I am trying to monitor now is a EF Johnson system, and told its implicit.
The 1st photo below is the bandplan in the scanner. The 2nd photo is the "Channel IDs" in the relm.
The bandplan (shown in the 1st photo) is what is in the scanner now, and it works fine. In other words, I can monitor this system fine using my PRO-197, with the bandplan shown in the 1st photo.
However, when I use the following bandplan in the Relm, it is not tracking the system.
Bandwidth= 6.25
Tx Offset= +
Tx Offset= 5.0000
spacing= 2.5
Base= 451.000
Type= FDMA
How would I take the bandplan in the 1st photo, and convert it into the 2nd photo?
I guess what is throwing me off is the Lo Chan and Hi Chan. Also, the scanner has 16 rows.
Thanks for any help I can get.
Bandwidth= 6.25
Tx Offset= +
Tx Offset= 5.0000
spacing= 2.5
Base= 451.000
Type= FDMA
