Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Iowa Radio Discussion Forum
Iowa Radio Discussion Forum - Forum for discussing Radio Information in the State of Iowa.
  #261 (permalink)
Old 09-16-2012, 8:43 PM
I think they were in the Crypt MOA today. Heard some chatter on the scanner before leaving the house this afternoon.
  #262 (permalink)
Old 09-17-2012, 1:44 AM
Originally Posted by splash1 View Post
Logs from 11-07-11,12:17 pm to 08:54 pm.
348.300 unknown VOLK area use with CYCLONE-21 at 02:PM
238.200 ACC/TAC A2A with unknown in the VOLK area 04:56 PM
Note other call signs used during practice sortie was MAD HOG and BROCHURE.
other freqs used
346.525 VOLK / PHOENIX
rick
Hi Rick,
348.300 WI F-16's new TAC A/A freq.
238.200 WI F-16's new TAC A/A freq.
Chuck in Detroit / NODAK 1
  #263 (permalink)
Old 11-06-2012, 8:40 PM
jimlawrence's Avatar
297.3 - sounds like refueling coordination. Anyone got any idea which AR track this frequency is associated with?
  #264 (permalink)
Old 11-07-2012, 12:59 PM
Ar406l
  #265 (permalink)
Old 11-07-2012, 1:30 PM
Originally Posted by autovon View Post
Ar406l
Is that a new AR track? I don't see it in the ap1b list of AR tracks.
  #266 (permalink)
Old 11-07-2012, 7:46 PM
406 Low and High have been around a while. They're more or less along the IA/MO and NE/KS border.
  #267 (permalink)
Old 11-07-2012, 8:19 PM
Thanks! Didn't see it in my documents. Do you know what the secondary/backup is?
  #268 (permalink)
Old 11-07-2012, 8:32 PM
396.200
Check out this if you haven't seen it.
http://www.carmachicago.com/profiles/Milair.pdf
  #269 (permalink)
Old 11-08-2012, 12:03 PM
Autovon and all, The Carma doc is a decent baseline in my opinion but you'll note the date of the document. A lot has changed since then.
  #270 (permalink)
Old 12-18-2012, 7:07 PM
Active Logs today:
354.1 - Chicago Center
372.0 - Minneapolis Center
319.2 - Chicago Center S. of Iowa City
363.1 - Minneapolis Center - NW Iowa
250.85 - IA ANG
238.9 - Air refueling
  #271 (permalink)
Old 01-28-2013, 12:43 PM
splash1's Avatar
Had a little time this am for monitoring .
10:12 am (260.200 REFUEL SEC 318) air to air chit- chat about being on wrong frequency.
10:32 am (391.000 BRAVO 2x primary) Refueling // updating eta and changing callsigns from (sounded like TREND) to DEMON 01 thru 06.
rick
  #272 (permalink)
Old 03-02-2013, 11:41 AM
Default Voice comms heard in Winterset, IA today...
I'm listening on a PSR-800. It's in the other room, so I haven't had a chance to look at frequencies, but will continue listening.
HAWKEYE ONE TWO is dropping GBU 12s on a treeline not far from here, "Dropping on the green smoke, and I do not see muzzle flashes; we will drop sensors on the site."
"Burma...good hits...no need for another reattack."
"Hawkeye One-Two has captured your location; sensors on."
"Danger close for a GBU-38 airburst."
"Cyclone push eleven, 288.3." "Checking in, Level 10,000."
"Okay, Hawkeye, that's all we got; we gotta go home for land time."
"Back to initial; push 3."
  #273 (permalink)
Old 03-02-2013, 11:42 AM
Also heard today: Mentions of CRYPT and callsign CYCLONE.
  #274 (permalink)
Old 03-02-2013, 12:08 PM
307.150 "Push Tower...Cyclones, push Three."
  #275 (permalink)
Old 03-02-2013, 12:09 PM
Cyclones again on 257.800.
  #276 (permalink)
Old 03-04-2013, 2:28 PM
A few notes from this weekend. Mostly PAT flights of BE20's out and about over the weekend, one flight decided to take a few touch and go's at MCW.
While I was out with the ADS-B laptop this weekend, noted coverage in the area of both VHF and Uniform frequencies, especially originating at MCW. I know many databases show Uniform frequencies that are not used here so here is the current usage. High altitude is 323.0250, coverage with a mobile antenna is about 30nm surrounding MCW. Low altitude is 257.6750, with a useful coverage of a bit less than the high alt frequency, again using a mobile wave antenna. With the MCW ATC antennas being at 1250 feet, the VHF range is barely 20 miles, even on top of ridges.
  #277 (permalink)
Old 03-05-2013, 7:45 PM
Crypt South, Central, North hot at 1830 hours. Hawkeye 11 flight of 2, Cyclone 21 flight of four in the airspace. Talking to Coffin Corners 311.300mhz.
  #278 (permalink)
Old 04-26-2013, 12:52 PM
Default Friday 04/26
Crypt North active with Texas 61, 51, 41, and 31 (F-16's from 111th FS/147th FW TX ANG Ellington ANGB, TX) fueling with Upset 51 and Upset 52 (KC-135). Lot of aircraft for such a small MOA.
Tactical is 321.200
  #279 (permalink)
Old 04-27-2013, 9:50 PM
Thanks for those reports, Ken! Very helpful!
  #280 (permalink)
Old 05-05-2013, 8:55 PM
Don't know if you knew it or not, but Crypt is the MOA in NW Iowa and Cyclone is one of the F-16 callsigns out of Des Moines. Take advantage of the F-16 traffic while you can, the jets are leaving Des Moines fairly soon.
Tags
sticky
