Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Iowa Radio Discussion Forum
Iowa Radio Discussion Forum Forum for discussing Radio Information in the State of Iowa.
Old 08-27-2009, 02:21 AM
Smile Drive Thrus.
just because... I have a list of used frequencys for drive thus but wondered if any one knew a few good ones to try for the local mcdonalds in Floyd county
Old 09-24-2009, 11:53 AM
splash1's Avatar
You should be able to find something by doing a google search. Here is a list from one site.
More Fast Food Frequencies
rick
Old 09-27-2009, 02:20 PM
Just use close call or signal stalker & find em
Old 09-27-2009, 02:47 PM
Personally, I've only successfully used Close Call once, and I was actually sitting in the McDonald's lounge. I found the frequency almost immediately. It was almost like a switch; as soon as I walked out the door, the signal disappeared. I'm not sure if whatever they put int the walls prevents it from going outside of the building, but that's what it seemed like to me. Maybe it's just so low-powered, it won't go through the walls. So if you're going to use Close Call (or equivalent), your best chance would probably be to sit in the lounge with a pair of small, discrete headphones or earphones, and scan for the frequencies that way.
Timothy D. Bennett/KJ4MUY
Cape Coral, Lee County, SW FL
Uniden BCD396XT, ICOM IC-706MKIIG
Old 09-27-2009, 07:26 PM
Also some of the drive thru can be heard for several miles, all depends on the frequency & surroundings
Old 10-01-2009, 12:26 AM
In my area, I've been able to pick up Arby's, KFC, LJS and Taco Bell for several miles. Was not able to pick up anything from McD's or BK outside of the lobby. One of the Taco Bell locations has a constant dead carrier and then the audio is turned on and off.
Similar Threads
FS: Dell floppy disk drive module ChescoAudioFeed Old Classifieds Archives 0 07-24-2009 11:33 PM
Hard Drive Clone b7spectra Computer 28 05-08-2009 12:54 AM
Mcdonalds, starbucks drive thrus cowboymike1971 Washington Radio Discussion Forum 3 03-25-2009 06:58 PM
Hard Drive S.M.A.R.T. Warning Thayne Scanner Programming Software 8 03-21-2006 01:43 PM
Dead CD-RW Drive matthewtomek Tavern Archives 27 01-28-2005 07:28 PM
