Before you reset the scanner, try programming Westcom into your scanner again (so you will have 2 Westcom systems) and if the new system works you can delete the old one, or you can just delete the Westcom system you have and reprogram it. If that doesn't work, I'm not sure if resetting the scanner will help but it might be the next step.
Donald
Originally Posted by jyoung1993
Thanks for you help Donald. I get the dispatch of the Fire and EMS on the VHF frequencies. I have all the control channels that were listed on this site programed and also the talk groups. Its odd because I have had this scanner for two year and then all of the sudden I get the dispatch on the VHF frequencies and then nothing on the talk groups after they are dispatched. The first thing I did was check to see if I had them locked out on accident, and they were not locked out. I don't know if I should reset my scanner and reprogram it and see what happens or not.
