Linn County P25 Simulcast System
timkilbride
Linn Co Iowa
The frequencies are in:
851.225
851.6125
851.825
853.0625
853.3125
853.6375
854.1375
854.5875
*855.7375
*855.9875
*856.9875
858.2375
858.7625
*Also used on the Cedar Rapids TRS
Tim
Radioman96p71
So far its just FCC license grants. I hear there is a lot of tech chatter on the edacs system over there tho...
Radioman96p71
It's reported that the system is now live, at least in the testing phase using control channel 851.2250
They appear to be following the same WACN/NAC as Johnson county, but with a RFSS of B instead of A.
More information to come.
radiowa
I programmed this into my handheld and was able to lock-on to frequency and could see it transmitting.
Are they using the same Band Plan as JCOM? I did not hear any voice transmissions.
timkilbride
Linn Co Iowa
I don't know the exact answer to your question but------
My understanding is that the two systems will be compatible....as in Linn County cars can call up JCOM cars etc. and vice versa.
The band plan has to do with programming some radio's (Harris to name one). For now, I would use the same as JCOMM(851.0125 / 12.5KHz).
This system came live while I was on the West coast so I haven't got to play with it yet.
Tim
Radioman96p71
Update to the info here, the WACN is the same as JComm (45564) but the SID is NOT 34, it is 39. I was mistaken earlier. They could have changed it also, since the site is so new i would say anything is possible. The RFSS is 0xB instead of JComm's 0xA. Just the one site was operating in C4FM, so they haven't gotten the simulcast portion running yet. I watched the system for about 2 hours and didnt see a shred of activity on it, tho they did move the control channel from 851.225 to 851.6125 and the site was advertising all the channels listed above. More to come for sure...
radiowa
Has anyone heard any traffic on the new system yet? I see the control channel transmitting data, but not voice transmissions.
timkilbride
Linn Co Iowa
Take a took at the database and wiki for Linn Co P25. It appears everything is just being patched from VHF to 800 for the time being. It looks like the dispatcher may have a new console that is tied into the 800 side. I didn't see any unique RID's show, just all the patch ones from the radio I was using. If someone in or near CR can setup unitrunker for a bit, that would help out.
Tim
dgmaley
Marion,Iowa
Just Test Audio
Yes, that's what it sounds like.
There is a lot of VHF radios that will soon be pulled from service. Anyone happen to know what's to happen to them?
btw...
All the multi-site garble is now gone.
Dave
WA0ZZG
IowaGuy1603
Jones County Iowa
They were all traded in.Most have been "out of service" for several months =-----I think only HT's are still in use (at least on the Sheriff's VHF system)
The Sheriff's dispatch equipment is being sold to another county (pending financing)
dgmaley
Marion,Iowa
VHF HT
A VHF HT was what I was interested in.
Most likely convert to 144-148 use.
Hoping they were not beat to death and able to find software to program.
The radios from China are so cheap now, this may be a mute point.
Dave..
timkilbride
Linn Co Iowa
Dave..
The M-RK's would *likely* require physical modification to get the VCO to lock in the 2M portion. The sad part is the programming cable cost more then the radio!
Tim
dgmaley
Marion,Iowa
Old VHF HT
Doing things like this was a normal part of rebanding a Motorola radio in the past. I have only one 'lunchbox' size portable left. This one is old enough to have pencil tubes.
The newer radios aren't as easy to hack into.
It was more fun when there was a 50 pound grey steel box in the trunk.
But, I still have my Bird 43 watt meter.
Dave..
IowaBrian
Michigan
Now hearing Marion on UHF again wonder if they are getting ready for a switch? Did hear them say they were testing out new HT's a couple days ago.
