Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Iowa Radio Discussion Forum
Iowa Radio Discussion Forum - Forum for discussing Radio Information in the State of Iowa.
  #21 (permalink)
Old 02-05-2013, 6:02 PM
Is anyone hearing any voice traffic on this system yet? I keep getting tones on channel 100...
  #22 (permalink)
Old 02-06-2013, 11:32 PM
Originally Posted by IowaGuy1603 View Post
I can't remember which frequency they had the "digital mode" active on .....F4 sounds correct but it has been so long since they used it I just can't remember
My HT doesn't have a digital mode for any of the Linn County frequencies I can use.......
Actually I think they can use it on all 4 main frequencies, but don't quote me on that..... The deputies didn't like it and just plain refused to use the mode.............instead they use cell phones.
Until they got their new radios this year you would occasionally hear dispatch tell a deputy "your digital button is on"
The reason I asked is I heard some ProVoice this past fall on F4. I wasn't able to get my ProVoice receiver turned on fast enough to see if it was "local" or even encrypted. I personally thought it was "skip", but your statements make me think different now.
Tim
  #23 (permalink)
Old 02-07-2013, 12:58 PM
Tim
Like I said ---------------I have no idea what mode the radio's used or what encryption was used because they hated using it..................but often accidentally pushed the button
Marion PD also was "digital" several yrs ago and it lasted about a month and they started back in the clear.
I didn't have a scanner capable of decoding so I didn't pay any attention...............
  #24 (permalink)
Old 02-22-2013, 4:02 PM
Does anyone have any updates on status of the Linn Co. P25 system?
  #25 (permalink)
Old 02-22-2013, 5:00 PM
I heard the techs talking getting full access to all the fire stations. Sounds like they are still installing/setting equipment up.
This may or may not be related to the system, but I'm seeing a Site 29 popping up on the EDACS side of things. Perhaps some in Linn county sniff this out?
Tim
  #26 (permalink)
Old 02-28-2013, 11:32 AM
I figured it out
  #27 (permalink)
Old 03-01-2013, 12:24 PM
Originally Posted by LowSignal View Post
I figured it out
Ben,
What are the LCN's? Or would Mr. Miller get upset you releasing that kind of information?
Tim
  #28 (permalink)
Old 03-01-2013, 2:10 PM
I think you put it nicely when you said some things are better left off public forums.
  #29 (permalink)
Old 03-01-2013, 3:33 PM
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.1.1; en-us; SCH-R530U Build/JRO03L) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30 USCC-R530U)
Hilarious. Why don't these people wait until the stuff is up and running? Trying to figure it out on a daily basis will just introduce erroneous information. Wankers I tell you. And the more you talk about it, the more encryption there will be.
  #30 (permalink)
Old 03-31-2013, 4:32 PM
Wirelessly posted (Droid : Mozilla/5.0 (Android; Mobile; rv:19.0) Gecko/19.0 Firefox/19.0)
my brother told me he talked to a tech from radio communications and the tech told him when the new system is done both linn county and CRPD will be encrypted 24/7
  #31 (permalink)
Old 04-12-2013, 8:25 AM
sounds like an extreamly accurate report,
  #32 (permalink)
Old 05-02-2013, 2:08 PM
Today Linn County F1 has been simulcasted on the P25 system......
I am picking it up using a wildcard on my PSR 800
  #33 (permalink)
Old 05-03-2013, 7:41 PM
I was able to confirm that LCSO F1, F2 and F3 are being simulcasted on LCOM.
It's nice to actually be able to hear them with some clarity
  #34 (permalink)
Old 05-04-2013, 7:16 AM
I assumed they were doing all channels but only caught F1 before the 1/2 second delay between the scanner and my mobile drove me nuts and I locked the P25 off my scanner
  #35 (permalink)
Old 05-04-2013, 8:51 AM
F1, F2, and point to point patched for sure. Some other unidentified GID's are 156, 158, 159. More then likely all of these GID's will change again to the format like Johnson County uses. GID's 100 - 103 are for testing.
Tim
  #36 (permalink)
Old 05-11-2013, 10:09 PM
Tim
57001 thru 57011 are being used now.
Tim
  #37 (permalink)
Old 05-12-2013, 9:24 AM
It sounds like the following channels are now active LCOM P25. (I haven't had a chance to map them to a TGID yet)
LCSO - F1
LCSO - F2
LCSO - F3
LCSO - F4
ISP - CR BASE
ISP - CR LEA
ISP - CF LEA
ISP - POINT TO POINT
MUTUAL AID
  #38 (permalink)
Old 05-12-2013, 7:54 PM
LCSO - F1
LCSO - F2
LCSO - F3
LCSO - F4
ISP - CR BASE
ISP - CR LEA
ISP - CF LEA
MUTUAL AID
So far the GID and RID's are being numbered a little differently then Johnson county was. I don't believe any radio's are actually live on the system other then the patch radios to bring VHF over to the system.
Tim
Tags
linn county, narrow band
