Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Iowa Radio Discussion Forum
Iowa Radio Discussion Forum - Forum for discussing Radio Information in the State of Iowa.
Old 12-04-2018, 10:35 AM
radioboy75's Avatar
Default Telemetry data on LEA (Area 1D)
Somewhat frequently, for like an hour or so at a time, I am getting some data noise on the LEA channel in my area, 155.790. The data sounds very similar to SCADA telemetry -- you know, like the data that is sent by water well monitors, gas monitoring stations, and the like.
Normally, assuming this is just some sort of DX, I would tone up my LEA channel, and call it good (use CTCSS to eliminate all traffic on the frequency unless it has the appropriate CTCSS tone).
The problem is, the traffic carries the 192.8 Hz tone, which is the same tone as Area 1D LEA. (In my area the closest repeater with that tone is Terril LEA.)
I assumed that some nearby utility department has a transmitter on (Area 1's) LEA input frequency, 154.770 MHz. But I have been unable to confirm that. Also, the data transmissions are very short, so part of me wants to say that they aren't actually going through the repeater, since there's basically NO repeater tail -- that the frequency programmed in the SCADA devices is the OUTPUT LEA frequency, 155.790.
Can anyone shed some light on this? Do any of you have this problem CONSTANTLY rather than occasionally? That might help us track down the location of the SCADA data . . .
Thanks!
Old 12-04-2018, 5:08 PM
MidwestRadioListener's Avatar
Seemed like I had read about this happening other places around the State but see you were involved in that thread as well so I guess that was no help but that thread has been idle for a few Months.
Old 12-05-2018, 7:00 AM
Default Cedar County
My scanner locks on for extended periods of time to 192.800 also, at various times. I have it programmed as a regular frequency. I usually just do a temporary lockout so I don't know exactly how long it lasts.
Old 12-07-2018, 9:07 AM
mws72's Avatar
192.8 MHz is within the Television Channel 10 bandwidth.
Michael W. Scheel - Davenport, Iowa - K0QCS - Davenport (IA) ARC - Muscatine (IA) ARC - RCMA IA-011 - USMC Corporal (2531) 1972-1976
Tags
dps, iowa, isp, lea, scada
