Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Iowa Radio Discussion Forum
Iowa Radio Discussion Forum Forum for discussing Radio Information in the State of Iowa.
Old 02-16-2008, 07:23 PM
Default Iowa City Monitoring
Does anyone know if it is possible to monitor the Iowa City trunked system as far north as North Liberty?
Old 02-16-2008, 08:53 PM
splash1's Avatar
Should not be a problem, but may need an 800mhz antenna like the radio shack model
20-283. What radio and antenna are you using ?
Rick L
Old 02-17-2008, 07:52 PM
I haven't decided yet, but most likely a RadioShack Pro-94 handheld. I do have an 800mhz antenna I can use if it makes much of a difference over the stock antenna. I'm looking at setting up an online feed from a condo up that way.
Old 02-20-2008, 11:22 AM
splash1's Avatar
Last Saturday on my way home from work i pasted through North Liberty with my pro 97 with a rs 800 rubberduck antenna and was able to pickup Iowa city trunk system all the way to Solon. I however did notice some weak areas in North Liberty.
So i would try to get your antenna as high as possible.
Rick
Similar Threads
City of Dayton talks of Joining Montgomery county's planned Regional Dispatch Center wolverine Ohio Radio Discussion Forum 0 11-21-2007 08:45 PM
After decades-long fight, Iowa airport embraces unflattering identifier SUX kny2xb Aircraft Monitoring Forum 9 10-23-2007 07:00 PM
Bellevue --v-o-l-u-n-t-e-e-r-- Fire Dept; Help Wanted NeFire242 Nebraska Radio Discussion Forum 23 02-08-2007 09:15 PM
Shoreline WA. plexus Washington Radio Discussion Forum 50 09-05-2005 12:28 AM
Monteagle City Hall Annex GlacierClipper Tennessee Radio Discussion Forum 0 10-28-2004 09:56 AM
