Originally Posted by JRAUDIOKS
i had this prior and it doesnt have the new finney county garden city police, fire ems, sheriff, on it and my uniden dealer said that if it was licensed more than a few months i should find it online somewhere. thanks for your info.
JR-
I think you are mixing some different terms here and it is causing confusion. No big deal- trunking systems are new to your area. A trunking system works with a set of frequencies (in your case 800 MHz) and then radio traffic is carried on "Talkgroups". The site that Fire576 posted has all the information that we have on that radio system.
The Garden City tower of KSICS currently uses the following radio frequencies (these will be changing in the next year as the whole state is rebanded).
866.42500
866.73750 Control Channel
867.06250 Alternate Control Channel
867.38750
868.37500
You will need to program these frequencies into your scanner. Then, because the "Talkgroups" that will be used by Finney County / Garden City PD are not in the database yet- you will need to run your scanner in "open" mode and listen to the radio traffic. From listening and some detective work you should be able to determine which talkgroup is used for dispatch, car to car etc. This is one of the interesting parts of the scanning hobby.
Once you determine what talkgroups are used, you can program the ones you want to listen to into your scanner and stop running it in "open" mode. And don't forget to return here and post the information you discover about your area.
Good luck!
