Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Kansas Radio Discussion Forum
Kansas Radio Discussion Forum - Forum for discussing Radio Information in the State of Kansas.
Old 05-23-2014, 4:30 PM
Question NOAA out of KCMO
The Weather Alerts system out of KCMO 154.1300, which system setting is best for receiving them ?
search, none, ctcss, dcs, p25 ? which is best ?
Old 05-23-2014, 5:18 PM
CTCSS 151.4 Hz is the correct tone for that frequency.
MARRS talk group 33017 more reliable if you able to receive it there.
The analog patch on 154.13 isn't always up. There also seems to be a 1 minute timeout, and if the MARRS user keys up before the analog repeater drops, the whole transmission is lost on the analog side.
Old 05-23-2014, 9:57 PM
Thank you !
Old 05-25-2014, 9:23 PM
On MARRS talk group 33017 is there a correct tone for that frequency like the 154.13 CTCSS ?
Old 05-26-2014, 6:07 PM
MARRS is P25.
I would suggest trying the Platte County, MO simulcast portion of MARRS. One of the towers is in Leavenworth according to the license.
Right now, the control channel is running on 858.43750. The database does not currently show it as a control channel, so if you are using the site to load up you scanner, you will probably need to add this frequency to your list of system control channels.
My decode of the Platte county is poor, so I can't guarantee that the MERS talk group 33017 is carried on this system, but it most likely is.
Old 05-26-2014, 6:27 PM
PVPD730's Avatar
Originally Posted by talkpair View Post
MARRS is P25.
Unfortunately, they aren't carried on Platte or the Independence site. I've only heard MERS traffic on the KCMO site.
Old 05-27-2014, 8:59 AM
Thanks for the reply's, I am having a hard time figuring out what frequency to use for ( noaa kcmo ).
Some are bad & some not so good. I'll try what you said, Thanks
Old 05-27-2014, 9:28 AM
Keep in mind that MERS is not intended to be an alerting system for use by the public.
Old 05-27-2014, 8:42 PM
On NOAA p25 type settings which is used ( Private or group ) in the 851.xxx frequency's ?
Old 05-27-2014, 10:44 PM
scannerowner's Avatar
The best weather frequency I monitor in KCMO is 162.550.
CERT Member
Scanners: Uniden BCD996T & Uniden BCD396XT
Radios: Baofeng UV5R, Yaesu FT2DR, Anytone 5888UV
Old 05-27-2014, 11:05 PM
Thanks for the reply on the frequency # 162.550,BUT how ever that wont work because that # is a COTINUALLY talking weather #.
