Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Kansas Radio Discussion Forum
Kansas Radio Discussion Forum - Forum for discussing Radio Information in the State of Kansas.
Old 07-13-2014, 9:11 PM
KAA951's Avatar
Default Osage County MotoTurbo system
Does anyone have any updates on the MotoTurbo IP Site Connect system being installed in Osage County?
WPNT670 (OSAGE, COUNTY OF) FCC Callsign Details
From reading the wiki and MotoTurbo literature, it doesn't look like this system will be able to be monitored and is not compatible with any other radios for interoperability purposes. I see they have licensed pagers on the system, but from what I have been able to find online there aren't any pagers that work with TDMA systems. Is there updated info on that?
MOTOTRBO - The RadioReference Wiki
MOTOTRBO
Old 07-17-2014, 7:52 AM
A lot of there cars are using the smaller phantom antennas then the bigger high gain UHF whips.
Old 07-17-2014, 5:19 PM
nec911's Avatar
I am taking two courses in my PhD program so I have not kept up with the news or talked to many folks down there.
About a month ago I did hear a couple things. I heard that they were looking into it but for Law only. I do not know if they are actually doing it or not. I believe that Fire/EMS and EM were going to stay on the same system. I can understand the reason for the Law wanting to having the option of secured channels. As homeland security professional I understand but as a scanner junkie I think it sucks.
I also heard that the radios they were getting or thinking about for Moto-turbo would be dual banded. I did not know such a creature existed, but I been wrong before.
I do think that after the last KEMA meeting I attended, there was talk about those on the state system having encrypted channels and it impacting interop. I was informed a couple weeks ago that if they go to Moto-turbo, they were going to have radios that will allow them to still have conventional UHF/VHF so they can interop with Fire/EMS and EM as well as other counties. Might be one of those things where Moto-bridge gets used more.
I know the radio I have with Osage County in it will not work other than the conventional, but I can understand why they might want to go to a more secured in this day and age. I can understand it, but as a ComL anything that makes interop more of a spit and bailing-wire fix at O-Dark-Thirty is concerning.
Old 07-17-2014, 10:39 PM
KAA951's Avatar
I was told that Osage was shooting to go live with this system in July. They had replaced almost all of their subscriber units with XPR6550's and 5550's. I am with you nec, I haven't heard of any dual band MOTOTRBO capable radios.
Old 07-18-2014, 12:13 AM
The radios are NOT dual band, they are analog/digital. There are several reasons that they opted to do what they did. Those being: secured channels, roaming without constantly changing channels, GPS, just to name a few.
All of the radios that were in use before the switch over to the TRBO radios were 15-20 years old. The encryption boards were all failing and no longer produced. The mobile radios were also no longer supported and no parts were able to be obtained for them.
In regards to interop, since these radios are analog and digital, LE will still have interop with the whole county. Nothing will change there.
In regards to the antennae on the cars, the high-gain antennas and phantom antennas are no longer used. All vehicles are using 1/4 wave antennas. (S.O. anyway)
Oh, and don't get me started on the Motobridge. Not that it would work anyway as there are no towers nearby except the borders of the county.
Old 07-19-2014, 7:05 AM
Any idea when there going to make the switch over?
Old 07-27-2014, 4:22 AM
Still a few things they are waiting on, so it could be a while still.
Old 07-22-2015, 10:13 PM
Any news on the mototrbo system? Any idea what radios their using?
Old 07-23-2015, 2:51 AM
Mostly XPR5550, 6550, a few 7550's. After some major set backs, the ball is finally rolling. Waiting on FCC license modifications at this time (moving to different towers.)
Old 07-23-2015, 7:21 AM
Is it just the SO moving to the system? All the fire departments well remain as they are?
Old 07-23-2015, 8:00 AM
Just law enforcement is moving to it.
Old 07-23-2015, 9:05 AM
mancow's Avatar
Anderson County has already made the switch. I've been listening with the ADCR25.
Old 07-23-2015, 9:55 AM
PVPD730's Avatar
Anderson County went DMR? Last time I was down there (not that long ago) Garnett was still analog. Thought they would eventually go KSICS.
Old 07-23-2015, 10:51 AM
mancow's Avatar
They are now DMR on 156.240.
Old 07-23-2015, 5:56 PM
I was in Garnett two weeks ago and they were still analog.
Old 07-23-2015, 6:09 PM
mancow's Avatar
They switched Friday.
Old 08-24-2015, 7:18 AM
The switch is set for mid-September. The infrastructure is in place and IP links are operational.
Old 09-11-2015, 2:24 AM
Annnndd it's finally going as of yesterday morning. Units are running on the "common" channel pending all getting in and re-programmed with digital templates.
Old 09-17-2015, 5:45 PM
Are the sheriff units using the system yet? How is sound and working out?
Old 09-17-2015, 8:00 PM
Yes, all law enforcement units are on the system already. Sounds awesome and have coverage where we didn't before.
