Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Kentucky Radio Discussion Forum
Kentucky Radio Discussion Forum Forum for discussing Radio Information in the State of Kentucky.
Old 07-22-2009, 08:05 PM
Send a message via ICQ to ShawnCowden Send a message via Yahoo to ShawnCowden
Default Kyem exercise invitation
Kentucky Division of Emergency Management
Department of Military Affairs
Boone National Guard Center
Frankfort, KY 40601-6168
INVITATION TO PARTICIPATE
On behalf of Brigadier General John Heltzel, you are cordially invited to participate in a statewide pandemic influenza exercise that will be held August 3-7, 2009. The communications portion of the exercise will begin each day at 8:00 A.M. and run until approximately 8:00 P.M. Monday through Thursday and will end at 2:00 P.M. on Friday.
This exercise is somewhat unique in that it will allow you the opportunity to participate in a statewide exercise without ever having to leave your community. As a matter of fact, we are hoping that you will work with other partners in your local community to determine your level of preparedness for just such an event. It is our hope that amateur radio operators along with government agencies and officials, schools, emergency response agencies, emergency management officials and businesses will join together as we prepare for the inevitable – another pandemic influenza. There is no limit to the number of operators that can participate and operators may participate at any time during the week long exercise within the time frames shown above.
One of our communications goals for the week is to use pre-identified 2 meter and 80 meter amateur radio frequencies to facilitate contact with all 120 counties in the Commonwealth. To some degree it will be like operating a week long net control. The amateur radio station in the Commonwealth EOC will be used to pass traffic and log check-ins during the week. The more operators we have check in, the better.
Daily messages will be broadcast from the State EOC at approximately 8:00 A.M. that will outline activities for the day. During the exercise a variety of injects or scenarios will be phoned, emailed, or transmitted by other means to participants from an exercise control center. Injects will provide opportunities for local participants to evaluate their ability to maintain operations and respond to the effects of injects on their local community. It is our hope that participants in your community will activate a variety of communication systems that will enable the exercise control center and other exercise officials to communicate across the state. We have specifically asked participants to consider using amateur radio as a source of communications to test communication systems that may be used for the purpose of maintaining local communications capabilities. Injects will flow to participants throughout the exercise even if the participant is only available to participate in the exercise for a few hours on a single day. Injects should be used when the local community deems itself active in the exercise. You could potentially be asked to assist with transmitting traffic for local exercise participants as well as our request that you check in with the State EOC.
Local clubs or ARES organizations may wish to participate as a group. There really is no limit to the ways or extent at which you may participate in the drill. Meet and decide what parts of your communications plan needs to be tested. Exercising gives us all the opportunity to identify weaknesses before the emergency occurs.
Once your involvement in the exercise is complete, we encourage you to provide us with some feedback regarding your participation. There is an established format we would like you to use. If you email me at charles.m.oneal@us.army.mil I will be able to email you a copy of the form we will be using. You may then complete the form and send your comments electronically to: paula.groves@us.army.mil.
As previously noted, our amateur radio system will be manned and operational from 8:00 A.M. until 8:00 P.M. Monday through Thursday and 8:00 A.M. until 2:00 P.M. on Friday. We will be utilizing the EOC call sign for all operations, which is KY4EOC, and will be monitoring the following 2 meter frequencies.
146.700 – CTCSS 79.7 – Brooks, Kentucky
146.715 – CTCSS 100.0 – Berea, Kentucky
We will also be monitoring the following HF frequencies.
 Daytime
o
40 meters – Primary – 7228.0 LSB
o
40 meters – Secondary – 7128.0 LSB
 Nightime
o
80 meters – Primary – 3.972.5 LSB
o
80 meters – Secondary - 3960.0 LSB
We will also be passing traffic from various sites via the following 70 cm repeater:
 444.050 – CTCSS in Williamsburg - 100.0; in Shelbyville - 95.1
The Brooks repeater is also available via Echolink – Node # 124812. Should we lose Echolink access through the Brooks machine, we will revert to the 444.125 machine in Lexington, Node # 319220
Stations checking in with the EOC will be asked, at a minimum, to provide the following information at a minimum:
 Call sign;
 First name;
County of operation; and
 Signal report.
In addition, stations may be asked to perform certain tasks or to handle traffic to or from their area of operation. Operators should have blank Radiograms (these forms are available at http://www.arrl.org/FandES/field/forms/RADIOGRM.pdf) or ICS Form 213s (available at ICS 213 General Message Form) ready for use, should traffic need to be passed.
Should you have further questions regarding the exercise, please feel free to contact your Local Emergency Management Director or your Regional Response Manager with the Kentucky Division of Emergency Management. You may also contact one of our Duty Officers, Patrick Compton, KF4FMZ, via email at Patrick.Compton2@us.army.mil, We hope that you will consider joining us for this exercise.
Sincerely,
/s/
Charles M. O’Neal, B.A., NREMT-P, KE4AIE
Assistant Director
Please visit the Kentucky Amateur Radio website
"KYHAM" at: The Kentucky Amateur Radio Web Site
to locate
your local ARES contact information.
Shawn Cowden, KG4KBU
London, KY
HOMEPAGE: http://www.myspace.com/KG4KBU
AIR AMERICA RADIO: http://www.airamericaradio.com
FREECYCLE: http://www.freecycle.org check it out its a neat site!!!
Old 07-22-2009, 08:45 PM
trashman43's Avatar
Kentucky DB Admin...
Sounds interesting.
Wonder if the KYEM/NG system will be involved also?
If so, It would be a good time to snag some of the Area 1,2,3 and 9 Frequencies and NAC's we need.
Old 07-22-2009, 10:53 PM
unitcharlie's Avatar
Good point trashman.... would be an outstanding time to finish the list of freqs/NACs. Will have to stay up late one or two days and take part as well...
Co-Founder/Active Member of the Central Kentucky Monitoring Team
Opinions based on MY experiences, real AND delusional...
WX4LEX
unitcharlie@radioreference.com
Twitter: CollierLEX18
Old 07-22-2009, 10:56 PM
that 444.050 link system has very good coverage even in downtown LEX
London, KY
Old 08-03-2009, 12:23 PM
As of this post, both EchoLink nodes mentioned are off.
Old 08-03-2009, 12:40 PM
yeah I see that and don't understand why
anyhow 91.5 is the PL for 444.050 in shelbyville ky also remb that 53.070 - no pl is on it but its linked to the 444.050 system
London, KY
Old 08-03-2009, 01:11 PM
also note that the 444.050 system is an IRLP system
London, KY
Similar Threads
NC Mil-Air Discussion Thread NCFireman11 North Carolina Radio Discussion Forum 352 Yesterday 04:37 PM
Vigilant Guard 2009 Exercise KAA951 Kansas Radio Discussion Forum 0 06-11-2009 09:34 AM
Roosevelt MOA frequencies ? cjrjr507 Military Monitoring Forum 2 07-02-2008 05:47 PM
Fed Freqs mike_s104 Virginia Radio Discussion Forum 7 05-08-2008 02:36 PM
upcoming exercise ka3jjz Delaware Radio Discussion Forum 0 06-18-2005 08:13 AM
