I think these are all the surrounding counties in your area? Do you have any of these freq programmed in your Pro 2020?
Larue County Kentucky
Larue County, Kentucky (KY) Scanner Frequencies and Radio Frequency Reference Larue County, Kentucky, uses conventional analog police and fire radio communications systems.
Nelson County Kentucky
Nelson County, Kentucky (KY) Scanner Frequencies and Radio Frequency Reference Nelson County, Kentucky, uses conventional analog police and fire radio communications systems.
Marion County Kentucky
Marion County, Kentucky (KY) Scanner Frequencies and Radio Frequency Reference Marion County, Kentucky, uses conventional analog police and fire radio communications systems.
Hardin County Kentucky
Hardin County, Kentucky (KY) Scanner Frequencies and Radio Frequency Reference Hardin County, Kentucky, uses conventional analog police and fire radio communications systems.
Hart County Kentucky
Hart County, Kentucky (KY) Scanner Frequencies and Radio Frequency Reference Hart County, Kentucky, uses conventional analog police and fire radio communications systems.
Taylor County Kentucky
Taylor County, Kentucky (KY) Scanner Frequencies and Radio Frequency Reference Taylor County, Kentucky, uses conventional analog police and fire radio communications systems.
Green County Kentucky
Green County, Kentucky (KY) Scanner Frequencies and Radio Frequency Reference Green County, Kentucky, uses conventional analog police and fire radio communications systems.
The Pro 2020 scanner can recieve the conventional analog communications systems. If in the scanners antenna range?
The Kentucky State Police use UHF digital communications. A digital scanner is necessary to be able to monitor the KSP.
I found the manual online also didnt know if you have one available?
http://pdf.textfiles.com/manuals/SC...020 VHF-UHF Scanner-Reciever_Short Manual.pdf
The only thing is there can only be 20 channels programmed so you will have to make sure the freq. you choose are within the scanners antenna range?
Sorry for the long post. Hopefully this will be of some assistance? My Kids love listing in on my scanners.
