Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Kentucky Radio Discussion Forum
Kentucky Radio Discussion Forum Forum for discussing Radio Information in the State of Kentucky.
Old 11-25-2012, 9:42 PM
scanningisfun's Avatar
Send a message via MSN to scanningisfun
Default Lexington Police West Sector
The database has two frequencies in the DB for LPD's west dispatch. Which frequency is actually West Dispatch? Is it the channel where the alpha tag has a "W" in parantheses with the tag set as law dispatch, or is it the channel that has west sector dispatch in its name, but with the tag set as law talk? Which channel is used for what?
Jacob
Old 11-25-2012, 11:03 PM
unitcharlie's Avatar
a Kentucky DB Admin...
Welcome to the confusion that is Lexington..... West is dispatched on both freqs.... Central will usually always be Lex PD 3, the other sectors could be any of 2, 4 thru 6.
Co-Founder/Active Member of the Central Kentucky Monitoring Team
Opinions based on MY experiences, real AND delusional...
WX4LEX
unitcharlie@radioreference.com
Twitter: Collier_LEX18
Old 11-28-2012, 4:04 PM
I will be in the area between Versailles, Lexington, and Mount Sterling for Christmas since we have family there. I have had all of KSP programmed for a while since we periodically visit my dad's hometown in Lyon County.
Jacob
Old 12-03-2012, 12:57 AM
Usually Lexington uses:
1- Information
2- Central Dispatch
3- Tactical or Special Event
4- East
5- West
6- Car to Car or Tactical or Special Event
Usually for part of third shift Lexington will "discontinue split-channel operations" and dispatch both East and West sectors on channel 4.
If you are ever unsure, just listen go by the first number in the unit number. 1-East, 2-Central, 3-West. Second number is shift, third number and letter is beat.
For example: 133B is the third shift west sector unit assigned to beat 3B.
Old 12-03-2012, 3:25 PM
1- Information
2- Central Dispatch
4- East
5- West
Thanks, this will help a lot. I am going to make a PDF of the wiki for Fayette County to put on my phone for quick reference. I am also tapping my Pro-79 scanner to monitor Montgomery County. Just got back from radio shack with some resistors, capacitors, and 3.5 mm jacks. I have DSD on my flash drive with cygwin1.dll. Pretty simple to use.
Jacob
