Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Kentucky Radio Discussion Forum
Kentucky Radio Discussion Forum - Forum for discussing Radio Information in the State of Kentucky.
  #441 (permalink)
Old 01-27-2018, 11:05 PM
buddrousa's Avatar
Here is a link to the Post 1 site map. The Farmington site looks to be the best site for Murray
https://www.radioreference.com/apps/...allsign=KFF361
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx4 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
  #442 (permalink)
Old 01-27-2018, 11:16 PM
Those are the freq I listed. I looked at the same map.
Sent from my Moto G (5) Plus using Tapatalk
  #443 (permalink)
Old 01-27-2018, 11:44 PM
If you are approaching the point of desparation, you might try doing a frequency search using the lowest licensed KSP frequency and the highest licensed frequency.
You might even go as far as doing an FCC license search using KSP's Federal Record Number of 000407021 to determine those lowest and highest frequencies.
Lastly have you attempted scanning the listed frequencies without a specific NAC? They could have made a change in that.
  #444 (permalink)
Old 01-28-2018, 12:21 AM
Are you referring to my question.
  #445 (permalink)
Old 01-28-2018, 1:10 AM
The main KSP radio tech was at a comex meeting a few years ago and said the KSP talkgroups will be 100 percent encrypted. He said the main reason was because of the YouTube radio recording of the trooper who got shot and killed in western kentucky
Sent from my Z956 using Tapatalk
Shawn Cowden, KG4KBU
London, KY
HOMEPAGE: http://www.facebook.com/KG4KBU
  #446 (permalink)
Old 01-28-2018, 1:29 AM
That will definitely put a damper on my feed.
  #447 (permalink)
Old 01-28-2018, 7:56 AM
buddrousa's Avatar
That is sad it come to that but that recording was a great tool to show how good of job the dispatcher did under the stress of that call that dispatcher did her job 100%. That could have also gone the other way if the shooter had gotten away and the public could have played a large part in locating the shooter but it is what it is.
  #448 (permalink)
Old 01-28-2018, 2:28 PM
Yes. KSP has a "core" set of frequencies and with planning and different NACs they can be used across the state. In other words 453.850 with NAC X could be used for 1A and 453.850 could be for 7B, etc.
So if the concern was a frequency change or perhaps NAC change, a search may reveal changes.
  #449 (permalink)
Old 01-28-2018, 5:15 PM
He did say he wanted it to be trunking system and tied into the Lexington and Louisville Metro and said other agencies were welcome to join it if they bought their own radios
London, KY
  #450 (permalink)
Old 01-28-2018, 9:00 PM
I have the Farmington tower in my radio. You listed Murray as a repeater site in that one post, so I thought that I was missing out on one.
  #451 (permalink)
Old 01-28-2018, 10:40 PM
I have every frequency on the tower in my scanner all on search its hard to test since they hardly ever use the channel.
  #452 (permalink)
Old 01-28-2018, 10:43 PM
I hope it is a statewide system and I hope it's not encrypted. It would make sense if they rented out spectrum to other agencies. Bowling Green police's system was bought by the city and they rent out the system to county SO, fire, and EMS. Helped with the cost of the new system.
  #453 (permalink)
Old 01-28-2018, 10:53 PM
He did say he would love agencies to give their frequencies up so it would help with maybe a vhf or uhf statewide system and in return every public safety agency can use it. That's why I am waiting on buying another radio.
London, KY
  #454 (permalink)
Old 01-28-2018, 11:01 PM
Do you really think ksp's will be encrypted? Will that mean the local agencies may be encrypted too? One reason I bought a new scanner was that I knew they were going to have to get a new system I assumed they would go Phase II. I chose the Trx-2 over the uniden because two local agencies are Nxdn and the trx-2 already has the support. I figured I'd be covered with what ever system they went with, didn't consider encryption.
  #455 (permalink)
Old 01-29-2018, 6:16 AM
buddrousa's Avatar
It will take almost 2 years to build out the system and who knows what will happen by then.
  #456 (permalink)
Old 01-29-2018, 7:56 AM
I figured it will be more expensive and they don't have a huge budget.
  #457 (permalink)
Old 02-06-2018, 5:39 PM
Default What is Nitewake?
I hear post 2 talk about NightHawk. What is that? Roadblocks?
  #458 (permalink)
Old 03-21-2018, 11:12 PM
Perhaps I could get some info on how to program the system in my 396T. I know it is not a trunked system. I would like to put in my scanner to listen to the next time I am up that way. If you can pm to me I would really appreciated.it. Many thanks red/
  #459 (permalink)
Old 03-21-2018, 11:35 PM
Program it as you would any conventional system. Just be sure to set the audio type to Digital. Also program in all the frequencies for each post noting you may have several. (Generally each post has 2 frequencies "A" and "B" in each county).
  #460 (permalink)
Old 03-21-2018, 11:44 PM
VASCAR2's Avatar
All the frequencies are listed for each particular transmitter site in the data base.
https://www.radioreference.com/apps/...1&aid=720#cats
You might also program the vehicular repeater frequency 154.665.
KSP uses 155.370 for point to point traffic as well as national interoperability 155.475 KLEEN.
KSP car to car and air to ground is 453.3000. (289 NAC)
Another air to ground frequency is 460.2500 (211 NAC).
I only programmed in the frequencies for Post 16 Henderson as I’m the closest to that post. There are only 16 post in the state and most of the frequencies are duplicated throughout the state. If you don’t enter the NAC you could probably program about 20 total frequencies and have coverage for the entire state. You can see how the frequencies are reused across the state by looking at the data base.
Tags
sticky
