Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 12-09-2009, 7:59 PM
Exclamation how to upgrade firmware TK-3180
Hello everyone, i have a TK-3180-K and i want to upgrade to the latest firmware and programming software so i can have MDC-1200 on this radio. I talked to my local radio shop and told them what i wanted and they basicly told me i was nuts because the tk-3180 couldnt do that. I was told they could and i have seen people post on RR that it was possable, could anyone set me straight,
thanks
mattgregg110@hotmail.com is my email if anyone wants to contact me off this post.
thanks
Matt
Old 12-09-2009, 9:08 PM
n7maq-1's Avatar
thanks
thanks
Matt
Is the shop a Kenwood shop? If so they should know how to do it, and they are just telling you that.
1. Start up the firmware programming software (Fpro.exe).
2. Set the communications speed (normally, 115200 bps)
and communications port in the configuration item.
3. Set the firmware to be updated by File name item.
4. Turn the transceiver power ON with the [S] switch held
down. Then, the orange LED on the transceiver lights and
“PROG 115200” is displayed.
5. Check the connection between the transceiver and the
personal computer, and make sure that the transceiver is
in the Program mode.
6. Press write button in the window. When the transceiver
starts to receive data, the [PG] display is blinking.
7. If writing ends successfully, the checksum is calculated
and a result is displayed.
8. If you want to continue programming other transceivers,
repeat steps 4 to 7.
Notes:
This mode cannot be entered if the Firmware Programming
mode is set to Disable in the Programming software.
6-4. Function
1. If you press the [Side2] switch (under of left side) while
“PROG 115200” is displayed, the display changes to
“PROG 19200” to indicate that the write speed is low
speed (19200 bps). If you press the [Side2] switch again
while “PROG 19200” is displayed, the display changes to
“PROG 38400”. If you press the [Side2] switch again
while “PROG 38400” is displayed, the display changes to
“PROG 57600”. If you press the [Side2] switch again
while “PROG 57600” is displayed, the display returns to
“PROG 115200”.
2. If you press the [Side1] switch (top of left side) while
“PROG 115200” is displayed, the checksum is calculated,
and a result is displayed. If you press the [Side1] switch
again while the checksum is displayed, “PROG 115200”
is redisplayed.
Note:
Normally, write in the high-speed mode.
Old 12-10-2009, 9:04 AM
I had my 2180 and 3180 flashed for mdc. Works great. Also displays the IDs on the display like it does for Fleetsync. I would tell them to contact Kenwood or look on the Dealers site for the latest firmware update for the radio.If they are not willing to help. I can put you in touch with a shop here in Tennessee that is capable to take care of that for you.
Old 12-10-2009, 3:24 PM
ok thanks everyone, they say they are a kenwood dealer but alot of questions they are asked they dont have a answer to.
Old 12-11-2009, 5:50 PM
burner50's Avatar
The Third Variable
What version of KPG-89 is required for MDC1200?
RadioReference.com Forums Moderator
burner50@radioreference.com
Old 12-11-2009, 6:04 PM
n7maq-1's Avatar
1.60 for the FPU.
This function can be used by the transceiver having firmware version 1.19 or later.
Jim
Old 12-11-2009, 7:35 PM
burner50's Avatar
The Third Variable
Figures
I only have 1.4
Cant justify spending the money for the new software for something I dont need
Old 12-11-2009, 11:15 PM
ok question, i got the firmware and software and did the upgrade. but when i turn the radio on to see the firmware ver i have it still shows 1.14.0, why is that. but i know i upgraded because my MDC is working great.
Old 04-07-2010, 7:34 PM
Question, where did poeple find thier KPG-89 v 1.6? I have V1.5 and cant find anyone with v1.6 for the life of me. Any help would be greatly appreciated
Old 04-07-2010, 9:04 PM
n7maq-1's Avatar
On Kenwood'd dealer site.
Old 09-15-2011, 1:30 AM
wx9kvh's Avatar
Default firmware
Where does one individual get the firmware for the tk-3180. I have kpg-89d v1.6. Does it come with the programming software or no?
Old 10-14-2017, 12:15 PM
Sorry to rehash an old thread but I noticed something interesting. I had originally v1.6, but my radio was password protected, so I needed the engineer version which was v1.5. Then I read this thread, went to reinstall v1.6, and it gave me the option to overwrite (update) existing files or uninstall the old version. I updated the existing files, now it seems all the engineer functions are available now in v1.6!
Just thought I'd share for those who may not have discovered this for themselves.
WQVN509
Old 10-17-2017, 9:33 AM
You can get the firmware/software from your local Kenwood Dealer. It is fairly priced and not
all that expensive. (Under 80$)
Lots of Kenwood radios are becoming multi-mode (NX-5000, NX-3000) and pretty much where
the product line is going to.
EFM
