Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 01-11-2012, 8:42 PM
Motoflightmedic's Avatar
Default Nexedge Trunking Users
Anyone here a user or a system administrator of a Kenwood Nexedge digital trunking system?
I have a few questions about the system and overall satisfaction with this technology.
Old 01-11-2012, 9:23 PM
Default Nexedge System Owner
We own a 5 site (soon to be 6) networked Nexedge system. I would be happy to answer your questions. Feel free to PM me for my contact information.
Works absolutely great.
Old 01-11-2012, 11:21 PM
The Nexedge trunked systems have a considerable amount of built in security. If your county is installing a trunked Nexedge system you will not be able to program the radios yourself. The frequencies and configuration data are stored in a special file and can only be edited by the system owner. The programming software needs a "System Key" file that is generated by the owner so that it can be enabled to program radios on the system.
The radios will not receive on a trunked channel even if you program the frequencies into it in simplex mode. Plus, there is no such thing as a receive only radio. Each radio must register on the system by transmitting its ID. The system will then enable it if it is valid. If the county lets you buy a radio, they can program it to receive only once it has transmitted its ID to the system.
These features are one of the reasons that Nexedge is becoming so popular with public safety agencies.
The solution is for the scanner community to pressure the manufacturer's to build a Nexedge capable scanner.
Old 01-11-2012, 11:37 PM
mmckenna's Avatar
I'm in the middle of installing a 5 channel single site 800MHz system at work. I went to a two day crash course at Kenwood early last year in programming the system. We played with a VHF single channel system for a while and we liked it. Looking forward to getting the new system up and running. I've got 300 hand held and 50 mobiles sitting in my equipment room waiting for me to program.
Next year we will likely be adding a second site.
All this for a fraction of the cost of P25.
Old 01-16-2012, 10:10 AM
Astro25's Avatar
I have 4 NXDN UHF trunking sites on the air. Works fantastic, end users really like the durability of the radios and the audio. We haven't had too many issues, and Kenwood's tech support has been great.
We still have a linked PassPort analog system that is to be changed over by the end of the year.
Old 07-14-2012, 3:43 PM
What kinda questions do you have?
We have a 8 site NXDN 800 Mhz system in service.
Old 01-24-2013, 11:05 AM
I built and manage a 11 site Nexedge system in south florida. Had to incorporate redundant LTE backhauls with VPN's but it's great. 43 channels total so far. If anyone has any questions or needs help I can help.
Old 03-29-2013, 7:56 PM
Default LTE ?
Just curious what Switch and modem you are using ?
Best Regards
Old 07-22-2013, 5:48 PM
HP MSR 20 20
Cisco RV082
Cradlepoints for the LTE backups.
Old 09-07-2013, 7:07 PM
I have been administrating a very narrow 5 site nexedge system. feel free guys to ask anything.
pm me any time.
Old 10-27-2013, 1:41 PM
HP MSR 20 20
Cisco RV082
What model cradlepoint are you using and are you still using the RV082 behind the cradlepoint for your VPNs? I also use RV082s for my wired sites but I want to add 2 more sites that AT&T DSL/U-verse can't serve and cable wants too much to run cable to the tower.
Old 11-22-2013, 1:32 PM
wireless_friendly's Avatar
Guys, you really sure that NEXEDGE trunking cannot be listened without transmitting ID? I've found some trunking system, programmed it as conventional VN channels, and able to listen it with no issues. I am pretty sure that it's trunking, because it uses dedicated control channel and voice channels jumps from time to time.
Old 11-22-2013, 1:52 PM
The Kenwood radios will not open the audio path if listening to a trunked transmission with the radio programmed in conventional mode. All you get is the busy light with no way to monitor it.
Let me know exactly what you are doing to be able to listen.
Old 11-22-2013, 4:54 PM
mmckenna's Avatar
Are you sure you are not listening to an Icom IDAS trunking system?
Old 11-23-2013, 1:59 AM
I am listening and it's Kenwood NEXEDGE. It's 200%. Because I know this network, know all hardware used, company who built, and... I have one legit terminal from this network. It's NX-200-K2. I just put same channels in my NX-700 (as conventional), set channels to VN, and I hear voice conversations. Voice channels are jumps, so it's looks like I hear trunking.
Old 11-23-2013, 2:01 AM
Maybe it's firmware depended feature? That's network few years old, but my NX-700 is FW v2.52.
Old 11-23-2013, 10:25 AM
Not possible. All kenwd NX radios from day-1 are inbred to go mute if it receives trunked signals. Even if you program an NX radio for analog it won't let you hear the buzzzzzzz in analog either. Maybe you are listening to private, non-trunked channels that happen to be on the same tower as the trunked system. Who's computer/SW did you use to program your radio. Maybe if you used their system computer with their system key?
Old 11-23-2013, 12:33 PM
No. I do not have access to system PC. I will re-check with my NX-700 to be sure for 200%. It was 1 year ago.
