Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 11-05-2013, 10:04 PM
Default kenwood tk 7150 low audio output
i have a kenwood tk 7150 when you tx the receiving radios have to turn the volume up real loud in order to hear and it is still quiet. i have changed mics and was wondering if any one else would know what it could be?
Old 11-05-2013, 10:08 PM
Are all the radios programmed with the same channel width? Sounds like your radio may be programmed to use narrow channel, while the receiving radios are set to a wide channel. Just a thought.
Old 11-06-2013, 7:10 AM
We just got a batch of them and the max. dev. on narrow is set to low from the factory. I think they only modulated 1.5 kc off the bat.
Old 11-06-2013, 11:47 AM
yes they are all programed on the same. currently using wide band except for one channel. and the other radios are programed with the same data off the software.
Old 11-07-2013, 8:23 PM
discombobulated's Avatar
Default Re: kenwood tk 7150 low audio output
What kind of vehicle are they being used in? If it is a noisy environment maybe try an external speaker.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Tags
audio output low
