Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 07-23-2014, 4:45 AM
Default Win 8.1 & KPG-141D
Hello
I have KPG-141D (ver. 4.4) and win 8.1. and programming cable from China
System win 8.1. sees the FTDI driver but program KPG-141D does not sees in comm settings this FTDI...
Do you have any solution for my problem?
Best regards
Stefan
Old 07-23-2014, 7:08 AM
Hello
I have KPG141 with Win 8.1 with no issues , Would you please explain more what do you mean by
FTDI driver
Thanks ,
Old 07-23-2014, 2:10 PM
Stefan,
I don't have your exact setup but you might want to try:
- Make sure your cable is plugged in before you start the KPG software: you might need to restart win8.1 to find the cable correctly
- Is the driver installed correctly: check out in Control Panel > Device Manager
- What COM port is the cable using (check via Control Panel > Device Manager and more to the point is it a COM port number that's available in the range that the KPG software can see (usually COM 1-20)
Old 07-24-2014, 2:32 AM
Hello again.
Thank you for all information. In device manager I have correctly installed USB serial Port (COM1) and USB serial Coverter, but KPG software has window Setup-Com is unavailable... This is my problem. Now I have KPG ver 4,7.
Best regards
Stefan
Old 07-24-2014, 4:59 AM
Ok,
problem solved.
My FTDI chip is not supported by Win 8 and 8.1 ...
Post close I go to the store
Stefan
