feliciepr7
- Joined
- Jul 15, 2015
- Messages
- 19
I need help to program my Kenwood NX-320 K2 to scan so I can be able to listening and add whatever I want. Can someone help me here?
Has MMCKENNA left the room?
OK, I'll cut in.
AH-hah! I'm getting the big picture now. Although your scan parameters are different from my example, they should work as long as the buttons are programmed to execute the scan functions.
Now let me back pedal a lot and ask you what you are trying to accomplish with this radio. You have entered two channels both with the same frequency and no QT/DQT signalling. If that is all you have in the radio, it makes no sense to scan two of the same channel. You have to fill out all the conventional channels and trunked systems you'd like to listen to with valid information to be able to receive and then set up scan to listen between them.
Are you expecting the radio to just scan the band and give you whatever it happens to come across? This is not the radio you need to do this. I suggest you study up more on your needs and see what exactly what will do this for you.
Is there a way that I can know or get that info for the NXDN? All I have is a Frequency Counter and CTCSS/DCS decoder but that doesn't work for this radio, the only thing I get is the frequency. I attached two images with the frequencies that a radio (NX-320) is operating too but that's all I know.
