Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
  #21 (permalink)
Old 01-15-2016, 5:53 PM
Default Looking for display size of nx5700
Just bought new jeep looking into buying and installing a nx5700 for use with fire Dept and ham bands. I have a smaller suv there is a spot that I would love that the display of Kch-20 would fit. Or the kch-15 size display. Any dimensions will be appreciated. I know I had a nx700 that the bracket made the display farther.
Plans on expanding the deck to uhf in future also with rc deck nx5800 so I don't know if the kch-15 would work or not. I have upload a picture to get a idea where I would like placement. Thanks Daniel N4EXW
  #22 (permalink)
Old 01-15-2016, 11:26 PM
Kch-19 not the 15
  #23 (permalink)
Old 01-17-2016, 11:06 AM
Here's a picture for comparison, my Kch-20 next to a Tk-7180 remote head, I believe the nx700 is similar in size to the 7180.
  #24 (permalink)
Old 01-17-2016, 11:07 AM
Need help ASAP, my computer crashed and I lost the NX programming software, what do I need to do to get it back? Stupid me had the codeplugs backed up but not the software..
  #25 (permalink)
Old 01-17-2016, 12:33 PM
03msc's Avatar
Where did you get the software??
Mark Arkansas
Uniden Whistler Kenwood Yaesu
  #26 (permalink)
Old 01-17-2016, 12:34 PM
From my dealer, I found all the files I need in a email, I re installed everything now my only issue is I need to somehow deactivate the software and reactivate it on the new operating system, I'm in license management right now.
  #27 (permalink)
Old 01-17-2016, 12:36 PM
You will need to contact land mobile support. They are the only ones who will be able to push your new id.
kd4efm Evans, sent using TapTALK on my HTC M9
  #28 (permalink)
Old 01-17-2016, 1:43 PM
The NX-x00 and the TK-x180 series are the same frames. (remote heads both use the KRK-10)
I could not find dimension in any of the manuals for the head it's self, sorry.
  #29 (permalink)
Old 01-17-2016, 1:49 PM
You may have to go with mounting a Pana-vise to the side and knuckle it over (mouting the head bracket
far right side on the pana-vise) that's if you want to leverage it infront of the gear shift control.
I would opt-out on mounting it above the acc. ports area. You will find your self taken the whole center
console apart when 10 minute job with a pana-vise would have been a better choice.
my two cents.
  #30 (permalink)
Old 01-19-2016, 6:52 PM
Is there a manual other then the help file that is included with the software? I have some scan issues I need to change, or read more about.
  #31 (permalink)
Old 01-19-2016, 8:43 PM
And those are?
  #32 (permalink)
Old 01-19-2016, 9:07 PM
How to keep deleted channels from scanning again once the scan has restarted? Can the screen only say scan like the X180's?
  #33 (permalink)
Old 01-19-2016, 9:25 PM
The nuisance delete is just that, if it's in your scan list, and you temporary delete, it does not remove it. You don't want it, deselect it from normal scan.
  #34 (permalink)
Old 01-19-2016, 11:32 PM
Default NX-5000 Series, Q&A, Info, and details
So there's a nuisance delete and scan delete/add?
  #35 (permalink)
Old 01-20-2016, 7:00 AM
When scanning, the same button you assigned for scan add/delete becomes the nuisance delete.
Same thing for Zone Add/Delete; you can nuisance delete the whole zone.
Once you stop scanning and then RESTART scan, the whole list/multi-zone lists becomes active again.
EFM
  #36 (permalink)
Old 01-20-2016, 11:03 AM
I understand, is there any way of removing the last received channel from the display so that the display just reads scan?
  #37 (permalink)
Old 01-20-2016, 1:11 PM
Nx-5000, no, just ignore it.
  #38 (permalink)
Old 01-20-2016, 1:12 PM
I am talking to KWD about it. They are aware. Right now it's a low priority.
  #39 (permalink)
Old 01-20-2016, 1:58 PM
I just hate how when your scanning and you lock out a channel it stays on the display until the next channel to open is displayed.
  #40 (permalink)
Old 01-20-2016, 10:04 PM
what fimware version are you using?
efm
