Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
  #581 (permalink)
Old 10-10-2018, 11:00 PM
Originally Posted by KD2DXF View Post
Has anyone had issues with Crossband Repeat "Mobile Relay" getting stuck on? I've noticed that a couple times the radio will freeze up, not respond to power off or exit, but will be stuck transmitting dead air. I have an NX-5700, and an NX-5800 tied together with a KCH-20R.
What's your firmware version????
Sent from my SM-G965U using Tapatalk
  #582 (permalink)
Old 10-11-2018, 11:42 PM
KD2DXF's Avatar
K 2.40.00
Matthew | KD2DXF
If today was your last day, and tomorrow was too late,
Could you say goodbye to yesterday?
  #583 (permalink)
Old 10-12-2018, 4:28 AM
Need to get 2.6 and load that in
  #584 (permalink)
Old 11-29-2018, 10:37 PM
KD2DXF's Avatar
Found today that the problem still exists. only this time it seems to only be the UHF Deck that gets stuck on. Again no lights and the display freezes. When i pressed Exit, it took the radio a full minute to actually power cycle.
Matthew | KD2DXF
  #585 (permalink)
Old 11-29-2018, 11:14 PM
Email me both files, and do a write up on it from start to lock up, need to be able to duplicate it on the bench before I can get it escalated.
