Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 06-17-2017, 4:36 AM
Default Mic Gain setting on TK-2170 & TK-2160
Hi guys,
is there a way to change values for mic gain settings on TK-2170 and/or TK-2160. I have looked in test mode menu, but found no options for microphone settings. I would like to change values for "normal" and "high" sensitivity option in the programming software for use in noisy environments.
Thanks!
Old 06-17-2017, 9:46 AM
Should be under options, not test mode.
Sent from my SM-G935P using Tapatalk
Old 06-17-2017, 11:57 AM
Under options you can just select normal & high settings, but I would actually need a "low" setting
