Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 02-12-2018, 2:53 PM
wcu02mpa's Avatar
Default EF Johnson 53SL model decode
Can someone decode an EF Johnson 53SL for me? 242-5477-801ACAB4
Also is the an EF Johnson model decode web page?
Thank you
I was trying to daydream, but my mind kept wandering.
Old 02-13-2018, 6:14 AM
ecps92's Avatar
MODEL STRING DECODE REQUESTS ONLY - Page 8 - The Radio Information Board
Thank you
Bill N1KUG
Cruise Ship Frequencies
http://www.scanmaritime.com
Old 02-13-2018, 7:12 AM
wcu02mpa's Avatar
Default Programming cable info
Thanks for info. Anyone know where I can locate a programming cable for that radio? Thanks
Old 02-13-2018, 7:20 AM
MCore25's Avatar
Amazon has working knock-offs for $30.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you…
Old 02-13-2018, 8:04 AM
wcu02mpa's Avatar
Default Link?
I think I found it
https://www.ebay.com/itm/EF-Johnson-...item2cbc175d33
Old 02-13-2018, 9:53 AM
wcu02mpa's Avatar
Default This one
That was not it. This is it
RFguys.com - EF Johnson 5300 53SL Ascend ES Radio Programming Cable
Old 02-13-2018, 12:43 PM
wcu02mpa's Avatar
Default This is a better one for the 53SL
http://www.repeater-builder.com/john...3xx-models.txt
Old 04-08-2018, 10:31 AM
Hopefully self promotion is not frowned on but here goes. I got sick of the programming cables, boxes etc that were "iffy" or cost more then the radio so I designed my own and sell them on EBAY.
Don't laugh I know its got blinky lights. I did it for a reason. If you have a new radio they tell you a few things. Such as seeing if the radio has power to the mic and if the current loop that communicates everything to and from the front panel / control head is working and the loop is making it to the mic jack. Also when you try to program the radio the data busy led indicates if data is moving or if its just blurped out a couple commands and died. So by blatant self promotion I give you https://www.ebay.com/itm/EF-JOHNSON-...IAAOSw~AVYpQN4
It comes with my zero anxiety warranty. If your unhappy? You get it fixed, replaced or refunded in what you decide is a reasonable time. *It doesn't include devices crushed, smashed or operated underwater. And due to the wonders of insomnia customers can call me as late as 11PM Central. I set up a facebook page https://www.facebook.com/refurbatron/ If your curious I have a short video and some misc blather about EF Johnson 5100 and 5300 radios that I focus on. Note if you try communicating using facebook be aware that I'm really not a big social media fan so phone, email or ebay are 100x better if you want to get in touch.
