Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 04-08-2018, 4:03 PM
Was emtfirebug14
Default Tk2180 emergency button
Hey yall trying to program my emergency button but can't remember how to do it. Anyone program this before that can help me out
Old 04-08-2018, 4:09 PM
Key assignment list
Sent from my SM-G935P using Tapatalk
mmckenna's Avatar
I've programmed them, what sort of issues are you experiencing?
Also, the button can be programmed to do a number of functions, "Emergency" is just one of them. Even under the emergency tab, there are a lot of options.
Old 12-06-2018, 7:46 PM
Was emtfirebug14
I am looking to basically set it as an emergency tone in case I'm in a situation where I may not be able to physically key up on radio. I would like to be able to just push a button and the personality channel remains open for a set duration where audio can be heard
Old 12-07-2018, 11:18 AM
you need to set up in AUX key select EMERGENCY, then used the fleetsync for it. then set in in emergency information your duration, in my option i set up the emergency cycles by number not infinite also set the emergency mode to audible you can set up also the text.
if you are using 2180 you can set up also caller ID for it so that you know whos key up and asking for emergency.
Old 12-07-2018, 12:30 PM
The 2180 has mdc signaling also
Old 12-07-2018, 1:00 PM
tk2180 no MDC-1200 but you are trying for emergency set up used fleetsync is easy to used and easy to set up.
Old 12-07-2018, 1:03 PM
Really? Mine has mdc 1200, I guess it's the option board or firmware unless it's fleetsync and they just called it mdc1200
Old 12-07-2018, 1:22 PM
oh im here in canada maybe US version has, but if you used have emergency set up, i rather use the fleetsyn more option than MDC
Old 12-07-2018, 1:23 PM
Probably the different model of the 2180. Fleetsync is nice though.
Old 12-07-2018, 1:25 PM
mmckenna's Avatar
MDC1200 on the TK-x180 line is a firmware upgrade for most radios.
Old 12-07-2018, 1:26 PM
What I was thinking I only seen the mdc firmware variety
Old 12-07-2018, 1:37 PM
mmckenna's Avatar
Latest (Nov 2012):
Radio Firmware 1.22
KPG-89 v1.61.
I'm using a TK-3180 and have MDC-1200 on it.
Old 12-07-2018, 1:45 PM
correct me if im wrong, but im using KPG-89D for x180 even i upgrade the firmware for the radio if your software dont have MDC-1200 you can't set up also the radio. im using MDC is just plain and simple caller ID but more than that i used fleetsync.
Old 12-07-2018, 2:53 PM
mmckenna's Avatar
You'd need to upgrade both the KPG-89 and the radio firmware to access the MDC-1200 functions.
Old 12-07-2018, 3:08 PM
sorry i been mix up, i ddnt notice that you need to select between Fleet or MDC if you select in the model portion and signalling. is been long time i never program the x180 anyway, the topic before is about emergency, i just focused for it, like i said is more option in fleetsyn than MDC,
i open topic about emergency for shutdown, but im using KAP 2 for accessories relay inside the RADIO
but i wan to know more about accessories output in the radio. with out using KAP 2, maybe theres a programming that can activate the accessories at the back of the radio.
Old 12-07-2018, 3:48 PM
Originally Posted by danielxgame View Post
sorry i been mix up, i ddnt notice that you need to select between Fleet or MDC if you select in the model portion and signalling. is been long time i never program the x180 anyway, the topic before is about emergency, i just focused for it, like i said is more option in fleetsyn than MDC.
While not the TK-x180 series, I have a NX-700 and NX-200 and the NX-x00 series you select MDC-1200 or FleetSyc signalling per zone. You can have one zone MDC1200 and another zone Fleetsyc.
Interoperatablity is not a technology, it is an attitude!!!
Old 12-07-2018, 4:40 PM
mmckenna's Avatar
Not much you can do with MDC1200 on these. As you said, FleetSync has more capabilities.
"Extended Function" "AUX" tab would be a place to look at output and input options for the rear connector.
Also,
You'd need to go under the "Model" tab for the radio and select MDC1200 or FleetSync for the specific radio. The radio will only do one or the other, not both at the same time.
Old 12-07-2018, 4:46 PM
So he is better off using fleetsync over the mdc on the 2180 with emergency and stun and such?
Old 12-07-2018, 6:07 PM
yes Fleetsync is good for emergency if you have NXDN radio is more easy for you to set up if you know how to set up the fleetsync.
