Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 04-12-2018, 7:13 PM
MSS-Dave's Avatar
Default NX3220 full keypad question
Any of you have one of these 3220 or the VHF version with a full keypad? If you do can you live dial or buffer dial the star and the pound key with it? Tk-3180 had to have a special firmware load in order to do this. I have an irrigation control customer that has been using 3180 for years but those are out of production. Kenwood does not seem to be able to answer this question even with an email to their special firmware support people. Maybe they're all confused with the merge with E F Johnson. At any rate I'm not willing to purchase a full keypad radio at this time for the customer if it doesn't fit the bill.
Thanks!
Old 04-13-2018, 3:08 PM
Not sure if this answers your question but if you depress the side PTT button and the keypad * or # key at the same time, then the * or # DTMF tones are sent out.
Old 04-13-2018, 3:19 PM
MSS-Dave's Avatar
Great that's good to hear that's one way for live dial. The other is buffer dialing where you enter in up to 30 some-odd DTMF numbers and then press to push to talk and it sends it all in a string can you do that? An example will be like * 1 * 2 * 3 * 6 * 9 #. Will it take the first * and send it from the buffer?
Thank you for the time!
Dave
Old 04-15-2018, 2:38 PM
I programmed one of the side keys for auto dial and could not get the results you want. I think you want “store and forward” for the DTMF
Old 04-15-2018, 2:42 PM
MSS-Dave's Avatar
Yes, not Auto dial but store and forward. With the keypad turned on, you could enter a string as I described above with a leading star and it will accept it with modified firmware in the x180 series.
Old 04-15-2018, 10:39 PM
It shows that option in the NX5000s, might send a note to kd4efm to verify. I don't have D3N
WQYN885 WQWX696 W6JBH
Old 04-16-2018, 6:44 AM
MSS-Dave's Avatar
Yeah we've been chatting, neither one of us have a full keypad NX3220. I'm calling Kenwood today to lean on them. Either confirm it works out of the box or if it needs custom firmware or just send me a demo so I can figure it out myself.
Old 04-16-2018, 2:22 PM
n7maq-1's Avatar
It does work.
Under BUTTON ASSIGNMENT
* and # Buttons Set to "Direct Button"
Primary Keypad Ops " AUTODIAL"
Then under DTMF encode
Check the "STORE and SEND" box.
Just tried it and it would make the Toro guys happy.
Jim
Old 04-17-2018, 6:50 AM
Thanks very much. Works good for irrigation control systems
Old 04-17-2018, 7:20 AM
MSS-Dave's Avatar
Thank you for your response Jim. I got confirmation that the radio does exactly as you described from a third-party.
So in summary to all reading, the radio will do store and forward DTMF dialing out of the box and there is a checkbox to enable the star and pound keys to be direct dial or used as control functions.
Old 04-17-2018, 10:28 AM
n7maq-1's Avatar
Correct, out of the box with the programming steps pictured. Standard (not custom) F/W 1.3 and the latest KPG-3DN. I did a string like *2*3*4 for the test.
Jim
