Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Kenwood Forum
Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include TK-series radios and NEXEDGE technology.
Old 06-13-2009, 07:56 PM
Default A few questions about the TK-790H
My main question about speaker pinouts was answered in the post before this one. A big thanks to Fire_Master_21
However, I have two other quetions:
1) Can I run 12 volt ignition power directly into the ignition sense pin on the 15-pin connector?
2) Assuming that I'm going to be running power to the speakers off the remote heads, will I still plug the speaker short plug with the wire loop into the back of the main unit?
Thanks for your help!
Jared
Old 06-22-2009, 12:55 PM
Just program the ignition sense to be off.
Using an external speaker you use different pins than using the internal speaker. Consult your manual.
Old 06-23-2009, 02:13 PM
The ignition sense is not programmable in this radio, it is selectable via a solder jumper inside the chassis. If you are asking, can you hook the ignition wire to the battery, to make the radio stay on all the time, the answer is yes. The ignition wire is pin 1 on both the control head and chassis accessory plugs. (you only need one)
The speaker shorting plug on the chassis enables the internal control head speakers, but I am not sure if you need for external speakers, just unplug it when you have it all hooked up and see. I plan to do this and try, the next one I work on.
Old 06-25-2009, 11:20 PM
n7maq-1's Avatar
The SP jumper needs to be in place unless you are getting the SP AU out of the 9 pin Molex on the rear of the deck.
Similar Threads
DPS questions for your serious DPSers... texasemt13 Texas Radio Discussion Forum 11 10-30-2008 12:52 PM
Kenwood TK 880 questions. davva General Scanning Forum 5 03-12-2008 05:16 PM
First time scanner user - WORTHY QUESTIONS Jon_in_Metairie General Scanning Forum 25 05-24-2006 08:21 PM
Resources and Specific Questions doublehelix General Scanning Forum 12 05-20-2006 01:39 PM
Questions and Answers about wireless phones Radiorick Tavern Archives 10 12-23-2004 06:11 PM
