Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Kenwood Forum
Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include TK-series radios and NEXEDGE technology.
Old 07-30-2009, 03:37 PM
Unhappy Tk-350(g)
Is there any other programs out their that don't require using a DOS based program to run?
At this point all I have is XP. Anyone have any tricks or hints?
I always get a R6009 error when trying to run the software in the command prompt....
Also, I have an older computer that I could turn into a programming computer, but I don't have a copy of DOS and not too sure how to change it over from XP to just DOS.....
ANY HELP WOULD BE APPRECIATED........
THANK YOU!!!!
Old 07-30-2009, 06:40 PM
DOSBox, an x86 emulator with DOS
My thumbdrive with the config got busted. All you need to do is check their wiki and figure out drive mapping and setting the serial ports.
I use this for my tk350 and tk250.
Old 07-31-2009, 12:03 AM
Sorry, TK-350 is a dos only program, too old to be upgraded to windows.
How old is your old computer. If it is a windows 98 OS, you can boot up into dos and the
software should work OK.
Old 07-31-2009, 03:20 AM
Send a message via AIM to scanfan03
Search the internet for a DOS 6.22 boot disk. Boot to it and then run KPG-23D. I program Motorola MTX-8000s along with TK-350s/250 with my Dell Inspiron 600M with a 1.7 GHz processor running XP all the time.
Old 07-31-2009, 04:41 AM
MTS2000des's Avatar
as others have said, most DOS based radio programming software does not play well in a Windows world, mainly due to the control Windows takes over the serial ports, not allowing a program to gain exclusive access, multitask switching which interrupts timing routines, etc.
Most NEWER (mid 90's and later) DOS programs will run without problems on modern PC's but some OLDER DOS software (such as Motorola STX, Saber, etc) won't function properly on anything faster than a Pentium 90. So, if you plan on acquiring older legacy radios, might be a good idea to acquire a 486 or P60/90 computer if you can find one. If not, here is what I did to be able to run DOS based radio programming software on my (somewhat newer) IBM ThinkPad T30 (P4 1.6GHz 512M RAM, 80GB drive):
1.Create a FAT16 DOS partition on your hard drive to store the software. The advantage is this partition can be accessed within Windows (great for editing codeplugs, most DOS software WILL let you open files, edit, etc- just cannot read/write to the radio in Windows). A small 200MB or less partition is more than adequate for storage of DOS programs, codeplugs, etc.
2.Use any DOS boot device of your choice (CD-ROM, Thumb drive, etc) to boot directly to DOS. Since DOS cannot recognize NTFS, you won't see your main Windows partition so you can't risk hosing anything. Logging to drive "C:" in DOS will actually take you right to the FAT16 partition you made with your DOS programming stuff on it.
3.Run your programming software from here. When you're done, restart into Windows normally.
Programs like Partition Magic are great for creating, resizing and managing different partitions on your drive. That is what I used to do the above.
All opinions, statements, posts, or information made public are those exclusively of the author, and not those of his employer, contractors or associates.
Old 07-31-2009, 02:01 PM
Thumbs up
I tried DOSBOX this morning and it worked GREAT!!!!!!
Thank you to all !!!!!
Similar Threads
Looking for Kenwwood tk 8180 and tk 3180 wanabe Old Classifieds Archives 0 07-29-2009 04:57 AM
Kenwood tk-790 and tk 890 FireMan16 Kenwood Forum 1 05-09-2009 10:31 AM
kenwood TK 250. kenwoodman Kenwood Forum 2 03-07-2009 12:45 PM
power help with TK 740 tunnelmot All Other Receivers 5 11-17-2008 12:53 PM
Wanted: Kenwood TK 2140 or TK 2170 VHF CODE03 Old Classifieds Archives 1 05-18-2007 10:49 AM
