I'm not fiamiliar with the 7180. But it's a bad idea to run two speakers at the same time. You will stress the audio amp and burn it up. I try to talk folks at work out of doing that and run a switch for internal and external speakers. When I install a TK-790 I would program one of the buttons to do the switching in the radio (A and B speaker on a 9 pin molex plug). The 7180 might be able to do that. As far as the mic goes, check to see if one of the pins is for mic level not line level audio. The 7180 does have a remote option and that would be the way to go. It may even have a two remote head adapter. I would, if possible, install a second setup with a remote head installed in a bin and the radio tucked away somewere, but that's a small radio and the remote head might not be needed.
Can you repeat the part after "listen carefully"?
