Kenwood does not support 5tone here in the US, so your 82D is a slightly different flavor. Mine only supports 2tone, dtmf and fleetstync.
Sounds like you have codes set up. Go to channel edit and select 5tone for opt signalling.
Go to EDIT>OPTIONAL FEATURES 1 and select either "AND" or "OR" for SIGNALLING.
If you select "AND", go back to EDIT>5TONE>DECODE and set "AUTO RESET TIMER" to your preference.
Also, EDIT>5TONE>DECODE will have "CALL ALERT". You can use that change the beeps when the radio decodes.
