Originally Posted by salcia
I have a TK-7180H and I am trying to set a front panel button so it will switch between High and Low power. I can't seem to find out where to set that. Hopefully there is a way to set a front panel button to switch between 50w and 10w using the Kenwood software.
It can not be done with the stock firmware. You might be able to get a custom rev of firmware to do it, you would have to ask your dealer to get this from KW.
Other than that you can program in a HP, an LP channel.
Jim
