Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Kenwood Forum
Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include the TK(R) and NX(R) series radios and their associated accessories. This forum is not for the TM series; use Amateur Radio Equipment.
Old 12-11-2009, 3:25 PM
Default TK-272G-1 extra channels
Kenwood lists the TK-272G-1 as 32-channel max capacity. I have one that I am able to put in a lot more. I currently have about 60-channels in it now. Is their a later version that allowed for more??? The software seems to allow for 128 zones providing one channel in each zone; I am thinking 128-CH capacity??. Radio perfoms perfectly from 144-170+ MHz.
Old 12-12-2009, 3:53 AM
n7maq-1's Avatar
The unit that you have was probably hacked into a TK270G. It is not hard, but most of the time the firmware does not get changed. When you read your radio what model does the software say it is?
Jim
Old 02-26-2013, 11:30 AM
Default RE: Extra channels in TK-272G
Jim
I also have noticed this anomality in a TK-272G I have. What is the process for hacking into it? Is it as simple as changing the model and downloading new info in to the radio? Also, when I read it, the radio always comes back as a 272G. You mentioned the firmware, can you explain a little more detail about changing it?
Thanks in advance
Old 02-26-2013, 9:46 PM
ramal121's Avatar
Yes! I used the software to change my 272 to a 270 (via the model pull down).
Now I have the 128 channel/zone combo. As far as I can tell, all other functions work as advertised. No special hacking needed. Don't worry about a firmware update if the radio operates normally.
With all the newer portables I have, my TK-272G (I mean TK-270G) has the size and performance that beats out the others. It's my main go-to for just general snooping around.
The fat one will never die! (http://www.kfat.com/)
